tigran
In rust we trust. Amen.
Club RR Member Number: 142
Hi guys. I have the bits that I bought for the solid state conversion on my E46 328, but instead I just wussed out and put a 'new' dual mass and clutch on the car.
What's included is a working, good condition second hand e30 325 starter motor (bought from Fritz Bitz), a good (not sure how they can be bad) solid flywheel from a e30 325 and a brand new LUK clutch kit to fit.
I am looking for £175 for this lot collected (it's hella heavy).
I also have a good working ZF 5 Speed that came out of my E46. I was going to use it to mock up the solid flywheel stuff, but seeing how the car is gone I have no use for the gearbox or the conversion bits.
I am looking for £50 collected for the gearbox.
If someone is interested in the whole kit n kaboodle I'll let it go for £200. If you're fairly local to Bournemouth I don't mind delivering it.
I'll put some pictures up later tonight, if anyone wants to see a standard set of transmission parts
Last Edit: May 26, 2012 10:07:45 GMT by tigran
tigran
May 18, 2012 16:07:01 GMT
Hup you get.
tigran
May 19, 2012 15:50:44 GMT
Just a quick note this will also fit on an E36 328.
tigran
May 20, 2012 12:46:06 GMT
Hup you get. C'mon need stuff.
tigran
May 21, 2012 10:52:14 GMT
Come on get ooop there.
tigran
May 22, 2012 10:53:42 GMT
As I've said in a driftworks thread for these I'm happy on swaps for CA18DET parts for this lot.
Will stick it up on the zone as well later.
tigran
Up you go.
Last Edit: May 24, 2012 6:16:21 GMT by tigran
tigran
I know someone on here is proper fed up with their rubbish DMF and would like a proper flywheel, and maybe a cheeky bit of lightening before it goes in for better BWAAARPING.
Stop being shy you little scamps.
tigran
Early morning upsky.
tigran
May 30, 2012 15:53:02 GMT
Up you get pleeeeze
