ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
May 30, 2012 18:02:14 GMT
30psi
May 31, 2012 21:05:34 GMT
Why's it need rebuilding?
1962 Ford Thunderbird 6.4L
1981 Datsun Bluebird SSS CA18DET
1981 Datsun Bluebird SSS SR20DE
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
My advice, for what its worth, the rochester is a tricky carb to set up properly, if your confident, go for it, if not, buy something easier like i did with the edelbrock option, it honestly worked right out the box once i had made the cable brackets etc up to suit my car.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
ToolsnTrack
Homebrew Raconteur
It needs rebuilt because its bleeding fuel like its had a drive by shooting. I reckon i may be lucky with just stripping and cleaning out the bowls, but it is so old looking a rebuilt may be a sensible option. I doubt any gasket will be reusable if i break into them.
i also have a crazy-tight budget at the moment, so rebuild rather than replace is the only choice of the 2.
stinkwheel
OK, so do you know about the old quadrajet dissimilar metal corrosion and epoxy-ing the plugs in base so they don't leak (cos' they do when old)
if not google 'quadrajet' leaks and 'epoxy'
ToolsnTrack
Homebrew Raconteur
I'm on it!
ToolsnTrack
Homebrew Raconteur
Hmm, that problem seems to be mostly manifested with fuel loss to engine. I have to say mine seems to be mostly coming from the pump lever on the top of the carb, and leaking to the outside rather than inside...
stinkwheel
Ah, OK. No worries. If you get really stuck drop me a PM. I now have a quadrajet spare ish thats been rebuilt. It may get you out of a hole.
ToolsnTrack
Homebrew Raconteur
Whats it off of? I may buy it anyway... (see, this is why I'm broke)
stinkwheel
Its a GM quadrajet off a late 70's car i believe. Will bolt right on. Has had new gaskets etc. Seems to work, but i never tried it on the road, i just swapped to the edelbrock.
ToolsnTrack
Homebrew Raconteur
What sort of price? I ended up going for a stateside bought rebuild kit, and then ripping the carb apart today regardless. Will see how it performs but I'm bracing for the worst all round...
I hate taking carbs apart!
Always end up with springs flying out and dropping screws, ballache.
ToolsnTrack
Homebrew Raconteur
But the flip side is you earn 100 man points for putting it back together again correctly.
