ftz313
does anyone know of anywhere the does line boring?
I know a lad who has an evo with a score in the bore and doesn't fancy taking the engine out.
Scotland location would be ideal !
line boringDez
@dez
Club Retro Rides Member 34
Jun 20, 2012 11:10:05 GMT
i think youre confused as to what line boring is.
line boring is machining the big ends in the block to make sure they're in-line with each other, i.e. the block isnt warped. it requires the engine to be out and totally disassembled.
overboring is machining the cyls to a different size, which sounds like what you need doing. again, youre not going to do it without the engine being removed and stripped to a bare block though. with very, very light scoring you might get away with just honing it, but chances are if its big enough to be recognisable as a descernable score, its too bad to hone and will need a bore.
Jun 20, 2012 11:19:18 GMT
In the old olden days there used to be mobile mechanics that would re-bore your engine in situ.
I've seen or heard of any since I started wearing long trousers though.
Koos
Jun 20, 2012 12:26:55 GMT
it really isnt done anymore tbh in situ....i'm afraid its a motor out and strip down job
if at first you don't succeed...use a gas axe!
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jun 20, 2012 22:00:38 GMT
^^ What they said.
There are still people who offer insitu boring but I've never heard of good results and personally would never chance it. Do it properly- do it once
Jun 20, 2012 22:16:14 GMT
you used to be able to get portable machines like the van norman boring bar, try this chap: www.superpowerunlimited.moonfruit.com/#he has a youtube chanel shows a van norman which may be suitable......
Jun 20, 2012 22:34:32 GMT
Honing maybe, but never heard of mobile boring.
given the amount of work required to get at the block to bore it, you might as well take it out!
Last Edit: Jun 20, 2012 22:36:12 GMT by welshpug
