The time has come to sell up, i've had this for going on 5 years now, it's been off the road for the last 2 but covered 17k in the time I had it on the road.
It does need work so don't think it will be an easy resto, certainly expect there to be more rot hidden.
at the very least it needs wings, front panel, work on drivers inner wing on the wing rail and battery tray area. the a-panels/kick panels need work but the rest of the floors appear solid. it is in a dark, damp garage so pictures aren't easy, but it's been under this roof for the entire time it's been off the road.
shell has covered 80k in total and it was a 1.3.
it comes with full basic suspension including all polybushes apart from rear spring mount. all glass minus windscreen, doors, bootlid, bonnet, rear bench, carpet and whatever other trim I have lying around in the garage. it will have a steering rack and column. at present the rooflining is intact. has the brake servo and full brake/fuel lines intact. has 1300 shafts but no cradle. If I get £200 the buyer can have my 1300 bottom end, done less than 100 miles since rebuild.
it had welding done on the near side rear sill before it came off the road, this may need re-doing depending on how well it was treated before it came off the road.
the boot looks ok, corners need looking at as ever.
the patches of primer on the interior are from about 4 years ago when I stripped it out.
Viewing is obviously recommended, I can't help with delivery of it but can help with moving it.
Price is £200, I still need to remove the various things I need which I hope to do this week.
Based in Darwen, Lancashire
