uncle silvia
Datsun Club UK - Devon & Cornwall Rep
Jul 11, 2012 11:58:21 GMT
Hi all Well as I said in a previous post I was having problems with my front brakes on mt B310 Coupe! I stripped them down and found the piston to be quite badly pitted and it was sticking! I rubbed them down and greased them up which improved them for a bit but they still arnt right!!! Now under braking it pulls lots to the left and is a bit scary! Now ideally I'd like to upgrade the brakes now rather than messing around trying to fix the old ones! I'd love a bit more braking power too so I thought about looking into the 280x swap! However, I don't know what's needed, how easy it is to do or how much it would cost!?!? I'd also like the struts so they can be converted to coilovers! Does anyone have any advice on this please do I can work out how to go about it! Cheers
1981 KE70 Corolla - 1978 B310 Sunny Coupe - 1977 Pink Clubman Mini Shorty
Jul 11, 2012 19:40:22 GMT
ZX or Z struts?
uncle silvia
Jul 11, 2012 20:05:44 GMT
Z I believe
Jul 11, 2012 20:10:49 GMT
Well...280Z's were never sold in the UK, so the struts are harder to come by. Probably looking at an e-bay jobby with them stripped of the calipers.
Calipers you can buy re-manufactured (check rock-auto, its significantly cheaper than ebay). Infact I bought a pair the other week for my Z!
As for sectioning the struts, check DirtyS30's blog for his guide. They are similar but not the same as 240/260Z struts, the strut tubes have a greater OD.
Essentially though, you grind off the spring perch, remove the old strut, cut the strut tube in half, insert new shorter strut, work out how much is excess on the top half of the strut tube, cut off the excess, weld back together, weld on new spring perch.
I can take photos if that helps?
Jul 11, 2012 21:16:51 GMT
280ZX
Alramone has done some and as the 280ZX strut is already shorter all that is needed is a coilover kit (from the MK2 Escort i believe) and a different master cylinder so you don't get a long brake pedal.
it's all on the Datsun forum somewhere. search Alramones posts.
uncle silvia
Jul 12, 2012 11:15:08 GMT
Sorry yes I ment I need 280ZX struts!! Should be easier to find
Jul 12, 2012 16:21:23 GMT
If you're having difficulty finding the struts, put a wanted post on zclub.net, you'll almost certainly get a reply with someone selling a pair.
uncle silvia
Jul 13, 2012 10:00:47 GMT
Cool cheers! Anyone know a rough going rate so I can price things up?
Jul 13, 2012 18:40:37 GMT
uncle silvia
Jul 14, 2012 16:38:04 GMT
Er I don't really have that space unfortunately! Gotta clear out some of my 6 cars as it is lol
