LowStandards
Jul 27, 2012 17:04:44 GMT
Wanted something to tootle round the show on, so I took a look at the pile of tat in the garage, lots of metal off cuts, a lawnmower and a kids big wheel trike were found. Razor scream machine Cut the back off, weld in a honda atc axle and all manner of tiny metal off cuts in random places for no reason to get I need to do something about this as what i've done is a mess and the clutch bell vibrates, but in 2 hours it aint bad. Now this isnt no speed machine, 5-10mph tops cause you know, it is a showground after all. Not started it yet, as I have no fuel, but mostly cause just looking at it scares the curse word out of me... Now useful warnings
Jul 27, 2012 18:16:50 GMT
WINNNNAAAAARRRR !!!!!!
You have been quiet a while mate, but what a perfect tool you have built.
10/10 for alll aspects.
I do love the warnings.
Hope to see video once you have fuel in that there beasty.
LowStandards
I've been busy doing my house up Rian, plus the misses won't let me in the garage!
I'll try and get some fuel later, though I'll be taking the chain off before I start it, that clutch ain't to clever at the min. It was held by a system of bars, bearings and bolts when it was on the mower, but now I've shortened it I need to figure out a way of keeping it on and central.
Plus it needs a heft chain guard, cause that would smart if it came off and had a go at me back/head...
Jul 28, 2012 14:48:56 GMT
Plus it needs a heft chain guard, cause that would smart if it came off and had a go at me back/head... Love it I can just imagine that chain taking your arm off at the shoulder with an armored plated guard!
MX5 mk1 - now Turbo'd Austin A35 van Suzuki SJ 16v
TS
Jul 29, 2012 18:08:05 GMT
So as its a fixed wheel (1:1 ratio fixed up front - so 10mph will require your legs to go round at 660 rpm, if its a 16" wheel) where will you be putting your feet when the motor kicks in?
Good stuff though.
Last Edit: Jul 29, 2012 18:10:28 GMT by TS
Jul 29, 2012 18:39:24 GMT
If that actually took 2 hours, you are a hero Re the pedals: I think you need to sub for some stunt pegs or Boadicea spikes
LowStandards
Jul 29, 2012 21:06:22 GMT
Its a freewheel so meh J69, I already had the atc axle with a bit of pitbike subframe welded to it, so it was mostly welding that to the trike front end, then mounting the motor, which is already bolted to a metal plate, so just tacked on. Trust me, when you see it you'll def know how long it took! Plus the missus wouldn't allow me any longer to play
Mr S
10-4 Good buddy.
Jul 29, 2012 21:33:33 GMT
Nice work Gimpy, and when it comes to the Mrs, MTFU....
LowStandards
Jul 30, 2012 11:25:32 GMT
Here we go, a look at the underside I welded the angle iron to the trike frame, then to the axle. This worked in tying the two halves together, but it was very flexible side to side, so thats what you can see lots of offcuts of bar to give it some strength...
quick and dirty, as it should be 8)
LowStandards
Well, I finally got some fuel, started the beast up, sat down, throttled up, lots of noise, no movement! The mower clutch just isnt up to moving the trike Had a think, looked around, then threw this together, so I will still have some transport for the showground! What you see here is an ATC70 front and rear end welded to a bent pitbike frame. The steering asssembly comes from the speed machine trike and the pitbike one was fecked. Fuel tank from the mower, engine from a cub 70/90 (its a bit of a hybrid, i forget how now, think its got a 90cc barrell and a 70cc head giving a silly CR) It pretty much is finished, i've welded the bars on in there position and ordered a new front sprocket and throttle cable. Need to sort out brakes though as it should do around 30mph and stopping would be comical without them...
nice project id like to do sometime
LowStandards
Awesome rebirth
Video no worky.
BiAS
Insert witty comment here
Club RR Member Number: 147
Awesome! glad I'm not gonna be the only one with something powered on the campsite
(car+wheels)-rideheight=WIN
Aug 11, 2012 15:45:53 GMT
That looks so death inducing, it's awesome.
