tigran
In rust we trust. Amen.
Club RR Member Number: 142
Speedo question. tigran
@tigran
Club Retro Rides Member 142
Aug 26, 2012 16:23:24 GMT
I know, yaaaawn. But it's one of those things that is causing me headaches. My HC Viva is fitted with a CA18DET engine and gearbox - this is setup for an electric speedo drive. The Viva is very much mechanical. I am hopelessly pap with cables and wires and whatnot. Is there a way I can convert the electrical signal being sent from the gearbox to a mechanical one for the speedo cable? I've heard the term of a stepper motor being banded about but thought I would ask people with more knowledge on the subject. Have a cool CROWN vic as thanks
Speedo question. ChasR
@chasr
Club Retro Rides Member 170
Aug 26, 2012 16:49:00 GMT
If I ever manage to make a chip to do pretty much what you want (I have the same issue with the Stag bar the fact that I have no speedo drive). I shall be in touch .
Aug 27, 2012 10:22:58 GMT
I have heard that www.speedycables.com/index.htmCan modify original speedo's by installing a stepper motor, to work off a electronic drive, not sure how much that would cost though But it's probably worth talking to them, I have considered using something like this www.ebay.co.uk/itm/220977699826?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_3466wt_946And driving it of a sensor, whith a magnet fixed to one of the brake discs, or running it of the diff flange, Depends on what your wanting to do, if it's using the original speedo, then it needs converted some how, depending on the pulse from the electronic speedo drive you have, that may still be suitable to drive an aftermarket one.
Aug 27, 2012 12:25:21 GMT
Fit the electronic speedo and print a new front so it matches the rest of the Viva dials, I dare say you'll want it to go up higher than a stocvk Viva one does anyway.?
tigran
@tigran
Aug 28, 2012 15:42:57 GMT
With my gearing the standard viva'll do. Also I :heart: the horizontal speedo - so will check converting the speedo.
