joda
Aug 28, 2012 14:09:46 GMT
Getting my car painted over the winter [White rs2000], its going to be getting painted inside, outside, upside down the lot i have been recommended two products so far: Standox 2k or Deltron 2k i don't know much about paint, so anyone willing to make a suggestion / argument for the above? thanks
retrobastard
Tits or tyres means trouble
Aug 28, 2012 19:05:26 GMT
Hi bud, standox, deltron, sikkens, ici, the list goes on! It all comes down to cost! To do this kind of job you'll probably need 10 liters of clolour if not more and 5 liters poss more of hardener!
Is the car being painted proffesionally??
I have used all brands of paint over the years all to varying degree's of satisfaction!
I have been using Lesonal 2k high solid (HS) recently and its been pretty good to me!! Its about £25 a liter!
2K is the best all round paint to use! But wear a good charcoal mask............... always!!!
Also when spraying white put it on carefully watching where you overlap........ white has a tendency to run very quickly when you least expecting it lol
Aug 28, 2012 21:46:15 GMT
if you afraid of runs mix it properly using a proper measuring stick and put in around 10% thinners and use some rocket thats an extra accelerator use also winter accelerator even in summer
Dave
retrobastard
Aug 28, 2012 22:46:08 GMT
if you afraid of runs mix it properly using a proper measuring stick and put in around 10% thinners and use some rocket thats an extra accelerator use also winter accelerator even in summer Dave I meant to a begginer but yes well measured paint is paramount!
joda
Aug 30, 2012 10:33:30 GMT
Yes getting a pro job done, as good as my painting is, id rather this get done right!!
Just looking to see what is the best, looks like I'm using Standox underneath and Deltron on the outside for a lush finish!
Aug 30, 2012 14:03:52 GMT
I wouldn't mix paint brands. You stand a chance of a reaction or mismatch. I'd go with the same company products throughout unless you have a damn good reason not to. Standox is pretty much top class stuff. Deltron is a PPG product isn't it? Good stuff too. I don't think you'd go wrong with either. If you are having it done professionally I'd go with what ever the painter is used to really, go with his recommend for your best result.
Aug 30, 2012 19:10:46 GMT
If you are having it done professionally I'd go with what ever the painter is used to really, go with his recommend for your best result. I was going to say this too. No point going for what people have said is best if your painter gets on better with, and gets better results from another brand.
