stefan
If it isn't broken fix it till it is
Sept 18, 2012 17:34:36 GMT
So as some of you will know I have just payed for a bentley 6.75L v8 turbo motor for may next project, a hotrod of sorts. It should be delivered thursday or friday
It is a carb motor from 85 so does anybody have any tuning info or good web sites for extracting more go from this engine, my google foo is weak on this one I am sorry to say.
If nothing is forth coming then I will just have to play about with it
Last Edit: Sept 18, 2012 17:35:55 GMT by stefan
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
Onne
Sept 18, 2012 17:49:39 GMT
It's the L410D engine apparently... But my google fu is weak too.
What can possibly go wrong by upping the boost?
RetroMat
Column Shifting!
Sept 18, 2012 17:52:10 GMT
I'm not sure too many people have played with the carb turbo. Rolls/Bentley after spending a huge amount of £££ on developing the Carb turbo they only used it for a couple of years then moved on the fuel injection Turbo R. The turbo R uses a much bigger turbo though looks like one off a lorry ;D Plenty of people have turned the boost up on the turbo Rs
froggy
Sept 18, 2012 19:36:37 GMT
i don't think the carb version is intercooled so a decent cooler and wideband lambda reader you should be able to run a couple more psi on the stock fuel pressure etc
stefan
Sept 18, 2012 20:49:16 GMT
Have to say my first thought was a large intercooler
stefan
Sept 19, 2012 6:56:33 GMT
They have a Solex 4A1 four barrel in a pressurised box and blow through that
Sept 19, 2012 9:46:40 GMT
Realsteel.co.uk for V8 tuning, they're wizards. PPC did this a while back using a fuel pressure regulator with a vacuum pipe connected to manifold to allow fuel pressure to rise according to boost levels. Have a wonder on the PPC forums as they'd be full of goodness
p.s. looking foward to seeing the finished product
if you're gonna do it wrong, you might as well do it wrong properly
Gud välsigna det röda blocket
nissan cube - jdm toy
volvo 940 turbo - 22psi
FOR SALE 2002 NISSAN CUBE
Sept 19, 2012 12:10:20 GMT
That project sounds amazing!
rodney
Sept 19, 2012 12:23:16 GMT
get ot the rollers for a set up and tune once its running etc ,
but a cooler will help no end , most carb turbos can go up a few psi with standard jets ,
the r5gtt goes to 14psi ok on standard jets, so upiing up round 8psi with a cooler should be sweet before a set up and jets are needed,.
Sept 19, 2012 16:40:24 GMT
It'd look hard as nails with a huuuuuuge super charger sitting in the V.... ;-)
Koos
stefan
Sept 26, 2012 20:39:58 GMT
Well engine and box are here and has been moved into the garage with lots of huffing and puffing, about as heavy as a small moon.
pics will follow tomorrow I hope
