75nut
Sept 25, 2012 11:42:01 GMT
So welded in my wheel well filler panel and coated in seam sealer and came back to this last night (right pain as was going to paint!) Whats gone wrong?? Its the same underneath as well! The metal was coated in Zinc primer, but I have done this beofre without issue. Don't like the idea of seam sealer on bare metal wanted some other protection in there.
90 Alfa 75 3.0 V6 Cloverleaf 79 MGB Roadster 88 Saab 900i Convertible 94 MK1 MX5 1.6 05 Volvo V70
Sept 25, 2012 12:21:41 GMT
is it really old tub of sealer? Was the join still hot from the weld?
75nut
Sept 25, 2012 12:22:41 GMT
No and no mate, fresh tub and I left it a day before adding the seam sealer
75nut
Sept 25, 2012 12:23:35 GMT
It seemed to be reacting with the zinc primer and the grey sealer was getting wet black streaks in it from the black zinc primer as I applied but I figures it would dry out ok.
Sept 25, 2012 15:03:24 GMT
I've had seam sealer react with primer too. Now I use cold galv spray and as long as fully dry (24hrs) not a probelm. I wonder if that might be the cause here - low temperature meant longer period should have been allowed for the primer to dry. How long from applying primer to seam sealing ?
paul H
75nut
Sept 25, 2012 15:37:43 GMT
Id say 24hrs
