leaky
Oct 11, 2012 22:28:18 GMT
1962 Morris Mini Traveller 1973 Commer Suntor 1979 Mini Clubman Saloon 1983 Austin Mini City e 1988 Austin Metro L 1989 Austin Metro 310
tontoe
Enter your message here...
Oct 11, 2012 22:41:58 GMT
It is probably going to need the bottom six inches all round ,heater channels bulkhead repairs rear cross members etc . usual beetle stuff i have about 20 under my belt !! its a small window pre 65 so more desirable but they do command high prices and as always you will need to do something spectacular to stand out from the crowds
life is just a game we play
Oct 11, 2012 22:53:09 GMT
If its complete and you can weld then its a great project. if its a runner then bonus. Check for float in the crank but it is a beetle so easy to work on. Do be prepared for a lot of welding but you can get pretty much all the panels. as for price god knows but if you fancy it looks like a decent project. the one I had was way worse than this. Thats why it ended up a trike.
sweaty palms slip off joystick
The floorpan itself doesn't actually look that bad, although I'd be checking it carefully with a screwdriver. Also check the front framehead carefully. As others have said, needs new heater channels and repairs to the inner wheelarches and firewall. None of the bits that you will need are hard to get, so if you're happy to do the rust repairs and you want a project, it looks okay.
What is the condition of the bonnet like? Good bonnets are usually hard to find. The engine lid is less rare, but still important, and check the condition of the fenders unless you're happy to replace them.
Personally I would run away from it, but I don't even own a MIG welder so I'm not in a position to do a major rust-repair restoration.
bl1300
ooer thats a bit crusty. If you can weld and want to do a fair amount go for it, if you can't start running and don't look back until you've crossed the border ;D
Current fleet.
Anything is repairable and Beetles are well provided with parts. However the costs soon mount up and you could find that, unless the car is very cheap, buying something in far better condition would probably work out a more sensible option.
Paul h
mungo
Oct 12, 2012 12:16:04 GMT
If it's cheap,your in no rush and you like welding go for it. ...........personally I'd save some more money and buy one that doesn't need so much welding ......but I'm a lazy curse word...
56' bug 2332 +ida's 56' lowlight ghia 72' bus 1600 devon 67' type 3 square - gone 83' gti - gone 90' gti 16v - gone 82' chevette - gone 70' GP1 Beach buggy -gone 78' lightweight landrover 3L v6 -gone 89' gti - gone 83' gti - gone
mudpud
Oct 12, 2012 15:35:11 GMT
If you are a masocist buy it if not run away as fast as you can and look for another, because the rust that you can see is only the beginning of the saga.
leaky
Oct 12, 2012 16:14:21 GMT
I can kinda weld although have never been brave enough to weld on a car. I guess this would be a great time to learn. Well its a 63 so as said more desirable. How much would you pay for this? It does have the bonnet and boot and all the fenders which are in good nic. Rough guess on price?
Oct 12, 2012 16:30:22 GMT
beetle prices are pretty daft at the mo, id value it at 500 quid-ish but ive a feeling these days it would be more like 800-1k for a complete fat-pillar project.
id expect that to need a grand it panels, it WILL need the majority of the framehead replacing, bulkhead panels and bottom plate at the least, so expect it to have a bit of tunnel bottom plate rot too.
60s cars don't rot as bad as 70s ones, but itll still need pretty much everything replacing, maybe even full rear 1/4s by the time the wingbolt line, body mounts and bumper mounts are shot. add to that both pans, both channels, front bulkhead, rear heater tube panels, inner rear 1/4s (which you cant get so need to be fabbed), hookys pillar bottoms, front bumpermounts/spare wheel panel, both valances, and that before you find any of the ticky bits of rot like bonnet/bootlid lips, rear end of the gutters, etc. yeah, all the panels are available, at a price, but they're not renowned for fitting very well, so unless youre a pretty proficient welder-fabricator, id forget about it tbh.
leaky
Oct 13, 2012 16:27:55 GMT
Thanks for all the advice. It has been taken on bored. I think I'll look for something else. Unless I can get this for £500.
Thanks.
