Diesel Turbos vs Petrol TurbosHARDCORE
@hardcore
Club Retro Rides Member 190
Oct 27, 2012 12:06:54 GMT
Sorry if this a stupid question (a lot of my threads seems to start with that ;D) but are there any differences between turbos for petrol engines and turbos for diesels engines? I have a turbo I'd like to put on my Audi dizzle but it's originally from a petrol.. Thanks!
Oct 27, 2012 13:05:50 GMT
I'm sure somebody with more knowledge will be along to inform you better but I always thought diesel turbos were smaller as the work at different levels of boost and compression than petrol turbos
OVY871
Owner of Austin A35 Saloon
Club RR Member Number: 66
Oct 27, 2012 13:25:57 GMT
Oct 27, 2012 14:43:19 GMT
Should be no problem at all, as long as it's not too small, which will make it overheat and blow hot air, or too too big and make your car boring to drive due to massive lag.
If it's cheap and you need a turbo just go for it. If it's of a petrol it's usually big enough, but when using turbo's scrounged from diesel engines for a petrol engine you usually want the diesel engine to have quite a bit more displacement.
Oct 27, 2012 18:35:52 GMT
I was told diesel turbo's aren't recommended for use with petrol engines because of the temperature differences - I was going to do the same but someone managed to heat the turbine and casing up enough to make it fail and enter the engine.
Oct 27, 2012 18:51:07 GMT
I was told diesel turbo's aren't recommended for use with petrol engines because of the temperature differences - I was going to do the same but someone managed to heat the turbine and casing up enough to make it fail and enter the engine. Tell that to everybody running holsets on everything from 220hp volvos to 1000++ v8's, 2jz and the likes Sure, if you rip the turbo of a 110 hp 1.8 diesel and attach it to a 2 litre petrol engine i'm sure you'll run into a bunch of trouble, but if you spend 15 minuts googleing the turbocharger in question i'm sure you'll come to a conclusion if it fits your application or not.
Last Edit: Oct 27, 2012 18:52:08 GMT by dude
Oct 27, 2012 21:15:02 GMT
EGT in a petrol are higher than a dizzel so turbos can suffer if they're not up to it.
Other way round shouldnt be a problem.
Koos
Oct 27, 2012 21:33:56 GMT
only thing to really watch out for, is that as above, the EGTs on a diesel, are FAR lower than on a petrol. As a result, there's less volume of gas to flow through the turbine, meaning the turbines on diesel turbos are far smaller than the equivalent capacity petrol turbo
I've been told the EGT is only a real problem when using a VTG turbo of a derv on a petrol engine
Oct 28, 2012 10:27:25 GMT
Yups - the heat of the petrol EGTs are far beyond what the vanes were expected to have to endure, so they *could* expand too far, and seize solid. It's also more damp than a diesel exhaust, so slight surface rust can build up, and kill it also
Apparently Porsche have made some petrol-specific VNTs? But they cost a LOT more....
Oct 28, 2012 10:39:21 GMT
Tell that to everybody running holsets on everything from 220hp volvos to 1000++ v8's, 2jz and the likes Was an Isuzu1.7TD on a Vauxhall 2.0 8v
@hardcore
Oct 29, 2012 13:21:15 GMT
Interesting readings, thanks!
The swop in question is the standard T2 (on my Audi IZ 1.9 TDi) for a T25 (from a Saaaaab turbo petrol) - if I've read the right things that's a direct replacement, but max flows around 400cfm, compared to ~300 for the T2.
