Hi guys I'm new to all this fabricating stuff. This is the first time I'm attempting something like this and i'd like to do it properly the first time, so I want to know how others would go about it.
Ive got to install a cable shifter into a mk1 golf and it has to mount in the factory position, but it has to come up as high as possible without fouling the centre console. This is for maximum exhaust clearance.
I've cut out the top of the centre console, thinking it would be a simple job of making up a plate and cutting out a hole for the shifter, however, I didnt anticipate it being double skinned
I want the shifter to mount up from underneath, but it needs to be raised a bit, so its not just a simple case of fitting a plate flush with the tunnel. I'm using a VAG cable shifter out of an Audi A3 if anyone was wondering. You can see it a bit in the first and fourth pics, albeit disassembled.
Here's pics:
Ok so where do I even start with something like this? I'm totally out of my depth and have come up with a solution or two, but I'm not too sure of them. What would you guys do in this situation? Remember the shifter has to come up above the tunnel whilst allowing the centre console to fit over it.
Thanks guys!
Here's pics:
Thanks guys!
