lemon
Gear head
Any guesses as to what this is from? The Case is Smiths, the Amp gauge is Lucas and the Oil pressure is Jaeger and if it is of any help, the bulb runs 12V... Any help appreciated!
More than it should be, but not as much as it could be
something aeronautical would be my guess. Lancaster bomber etc...
I would guess either boat or light aircraft. Whatever it is, it must be pretty old and probably quite small if the electrical system was only rated at 30 amps. This makes me think small boat rather than aircraft, although I may be wrong. 30 amps at 12 volts is about right for a small car from the '60s, but the gauge housing doesn't look like one from a car. Could have even been for a tractor or earthmoving machine maybe?
jonw
Can open a Mouse with a File
That's a proper heinz 57. I would guess that the ammeter is not original. what stamps are on it??
Suzuki SV650R The good Triumph T20 The Bad BMW G650GS The Ugly Matchless G12CSR The Smokey Toyota Hybrid One pint or Two?
Ingredients of this post Spam Drunken Rambling of author Bad spelling Drunken ramblings of inner voices Occasional pointless comments Vile beef trimming they won't even use in stock cubes
spiny
Wiki Admin
Club RR Member Number: 167
Any guesses on this?spiny
@spiny
Club Retro Rides Member 167
the '-something- motor accessories' stamp would suggest it's an aftermarket item to me.
Last Edit: Nov 6, 2012 17:02:17 GMT by colnerov
lemon
Gear head
Thanks for the input chaps,
Jon W - What kinda stamps are you thinking? If you cant see the one on the face to well, it reads 'Smiths Motor Accessories Ltd - England None-o-Jewels'
It all looks as if it is a standard, production unit by its construction
Other than that and the makes on the gauges, I haven't got much to go off. Its just really weird that its 3 different makes for the 3 parts, in one gauge! The square gauge holes and square back plate are another weird feature, look abit 'hardcore' (?) for most cars which made me think aeronautical or military?
Last Edit: Nov 6, 2012 18:33:17 GMT by lemon
Copey
smiths did make a lot of aircraft gauges, so may be from a plane, not sure about boats though
