Hi all, I've recently upgraded my MGB to use one 12 volt battery so I've got the old 6 volts here for sale.
They are all 'type 421' batteries (can get dimensions if wished), the vital stats are 56 Ah and 270 CCA
The first one is pretty much brand new, I bought it last month before having the change of heart and going to 12 volt power
The other two were claimed to be pretty new when I bought the car
One produced a full voltage when tested using the battery tester at work
And the last one here came up as being 'unserviceable' on the tester but I can throw it in with the other two if desired as when I tried to hook it up to a charger it did start to charge, its up to you
Since two of the batteries are in fine working condition and one is practically new, I'm asking for £50 for all three, but am open to any offers
These are for collection only as they weigh a ton and could probably leak etc.
Though I will be going to suffolk on friday so if you're out that way I could drop them off
Reply or pm me, think thats everything covered, thanks!
