Wow. Looks great. I used to own a white one of these a few years back (now I have an st162).
I can see a few bits just from the pics, but what mods have been done?
How do you find the st162 compares to the st165?
Thnk you for your comments..
They are getting VERY rare here in the UK, not that there ever was very many here to start with..
spec...
Engine/Inlet/Exhaust
Rev2 Engine fitted with Eagle Rods, Ross Pistons, and ARP Hardware through out etc
Fully reconditioned Cylinder head, mildly ported, complete with Resin spacer in place of T-vis
ST205 Inlet Camshaft fitted
Adj Exhaust Cam pulley Fitted
Radtec Aluminium up rated radiator complete with Spal fan, TRD Thermostat, Swirl Pot & Header tank
TTE Grp ‘A’ 1.4mm MHG
Enlarged ST165 Throttle Body/Plate
Adj Fuelab FPR, running higher than stock pressure, 540cc Injectors
Turbo Technics S148 Hybrid Turbo, Running around 1.4Bar on the road
ST205 Charge cooler complete with pump and MG Metro Cooling radiator
Aquamist Water Injection, with additional lifter pump
Additional Oil cooler fitted in lower aperture
Walbro High Pressure Fuel pump
Apexi Power FC ECU, Mapped by Ryan @ 2BarTunning – 377/353 FW BHP-Ib/ft @ SRR
Straight intake fitted with Blitz SUS Air Filter
Full 3” system, turbo to tip
Transmission
ST205 Gearbox (4.285 FDR)
Twin Plate Fensport 700 Series Clutch, complete with Lightened FW
Lightweight Two-piece Prop shaft
TRD Front & Rear Gear Box Mounts
Solid gear shifter Bushes
Rear Torsen Diff
Brakes
Front- AP Racing 4Pot callipers, 315x32mm Vented & Grooved Discs, Ferodo DS2500 Pads
Rear- ST205 Twin pots, 315mm Vented Discs
ST205 Brake Booster with Stopper
SS Braided lines
Motul RBF600 Fluid
Suspension/Wheels/exterior
Koni Adj shocks all round with Custom wound lowering springs
Tein pillow ball Adj front mounts
Whiteline Anti lift/caster kit fitted
Whiteline Strut Brace
Whiteline Rear Adj ARB
Whiteline Poly bushes through out
SSR Comp C 16” Light weight wheels
15mm H&R Spacers Front and Rear
Bumper vents to aid with cooling
Bonnet vent to Aid with cooling
Fibreglass Sunroof to aid with Rust!
Always more to be done!
