ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Toyota T50 alternativesToolsnTrack
@overdrive
Club Retro Rides Member 134
Mar 20, 2013 10:00:51 GMT
So I think I may build my wee locost with a 4AGE. PROBLEM IS THE t50 isn't exactly a common box. Managed to find a bell housing for a t50, but not the box.
Has anyone done another box to make a 4age rwd? Any hints or tips?
Toyota T50 alternativesDez
@dez
Club Retro Rides Member 34
Mar 20, 2013 11:38:26 GMT
You can get abellhousing to type9. Works out significantly cheaper than what t50s sell for,!
ToolsnTrack
Homebrew Raconteur
@overdrive
Mar 20, 2013 16:09:02 GMT
Type 9 my best bet? Will do some rummaging....
Mar 20, 2013 16:59:59 GMT
A lot of the corolla boys are running type 9's in rally cars now as they're easier to find.
Mar 20, 2013 17:29:20 GMT
So that's why type9s are getting expensive!
Koos
ToolsnTrack
Homebrew Raconteur
@overdrive
Tell me about it MDH! Struggling to source a cheap one!
I wonder if BMW do removable bell housings on the getrag range?
Just a curse word the W58 is no use... Lots of old n/a supras with them.
Mar 21, 2013 23:54:55 GMT
I was looking for a W58 for ages but they seem to be stupid expensive too.
I picked one up cheap on evilbay and it ended up being an R154 (I think) supra turbo box. Didn't realise til I got it home...:-(
I don't think bimmers had removable bell housings, unless you have a short temper and a big hammer.....;-)
Oh for the days when you could pick up a good Type9 for under £50
Koos
MrSpeedy
East Midlands
www.vintagediesels.co.uk
I think I paid a score for mine 3 years ago
can you translate... I don't speak cockney!
Koos
ToolsnTrack
Homebrew Raconteur
@overdrive
Mdh, u probably lucked in there, the r154 is pretty robust and desirable. Drifters love them.
Mar 22, 2013 10:49:37 GMT
Mdh, u probably lucked in there, the r154 is pretty robust and desirable. Drifters love them. Maybe, but it doesn't fit between the chassis rails on a triumph Vitesse, so it's pretty useless to me. Keep meaning to eBay it again!
Koos
Mar 24, 2013 11:58:48 GMT
The big hammer is my favourite tool.....
Koos
Mar 24, 2013 14:04:58 GMT
Time to hammer the chassis rails... You have to hammer the chassis rails to get a W58 in a Vitesse anyway. R154 - no way! Should be able to sell R154 for decent money and possibly even swap for W58...... Nick
MrSpeedy
East Midlands
Mar 24, 2013 14:36:51 GMT
can you translate... I don't speak cockney! Sorry old bean - Twenty pounds Sterling
ToolsnTrack
Homebrew Raconteur
@overdrive
Mar 24, 2013 19:49:40 GMT
MDH, a perfect excuse for le welder....
What are you thinking for that r154? Can you take a snap of the internal of the bell housing? I'm planning nasty things.
Copey
Mar 24, 2013 21:00:55 GMT
as above you can buy a bellhousing conversion to fit a Ford Type 9 box (out of a sierra or a pinto powered 5-speed Capri), but not overly cheap, £220 for the bellhousing and £100-150 for the box, depends on your budget www.rwdmotorsport.com/Bellhousings/Toyota-4AGE-to-Ford-Gearbox-Bellhousing/prod_58.htmlif you go this rout be carefull not to buy a 2.8i Capri box, they are different, easy way to tell is (if the box has the original bellhousing) sit it on its face, if the box sits flat its for a 4-pot, if the input shaft sticks out and the box wiggles about its a v6 box
Last Edit: Mar 24, 2013 21:03:44 GMT by Copey
Mar 24, 2013 23:53:50 GMT
MDH, a perfect excuse for le welder.... What are you thinking for that r154? Can you take a snap of the internal of the bell housing? I'm planning nasty things. Not got any of the bellhousing at the moment... I can take some next time I'm down there. As for the Vitesse, ive got another box in mind...
Koos
Mar 25, 2013 20:51:16 GMT
Does the 4age share a bellhousing pattern with a 3sge or BEAMS engine ? This was fitted in JDM altezza which is rwd, using the Aisin AZ6 6 speed box
Leen transmissions do a conversion front end for this gearbox to a 4 age, to fit in an AE86 corolla.
ToolsnTrack
Homebrew Raconteur
@overdrive
Mar 26, 2013 13:14:01 GMT
No, they are different blocks. Shame as it would offer a lot more options.
