stefan
If it isn't broken fix it till it is
As thread title I am looking a very strong axle to fit under the rear of a series 3 landrover as I want to change the engine, the 200DI is a rough old engine that will shake you teeth out.
I do not want fender flairs idealy and I am not bothered about the diff ratio as I would not be running 4x4 if I change the engine.
So strong and narrow ish is good, not bothered about welding on spring mounts I can do that no problem.
One last thing can I weld the front axle swivels to a length of steel bar for the front axle without diff in.
Last Edit: Mar 26, 2013 9:45:36 GMT by stefan
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
Salisbury from LWB should be more than enough for a 200 TDi. Ratio might be a problem though as you'd really need a Stage 1 axle if 3.44 required - which are as rare as poor quality wobbly children's play pony poop. Why not upgrade your existing axle as there are aftermarket stronger half shafts (the weak point) and diffs available. If you go to something like Dana axles (44's fitted to my Mahindra :-) ) then remember you'll need them front and back to match ratios. Jeep CJ5 & 7 should be able to donate suitable narrow Dana axles but can be quite expensive.
Paul H
stefan
Mar 26, 2013 10:25:02 GMT
As said above I am not keeping the 200DI or using a 200TDI. I am also not keeping the 4x4 system so ratio is not that important, around 3.5 would be good though
Mar 26, 2013 11:27:04 GMT
What engine will you be using Stefan?
stefan
Mar 26, 2013 12:44:20 GMT
A Bentley 6.75 turbo V8 engine and box
Mar 26, 2013 12:52:07 GMT
I misread and assumed you were going to be fitting a 200TDi. ;D If you are going to fit such a Bentley engine then I'd say go for a US axle and have it narrowed to fit. Here is a comparison of the various types - www.jpmagazine.com/techarticles/154_0708_weakest_to_strongest_axles/viewall.htmlI'd say at very least you will want Range Rover / Discovery swivels so disc brakes can be used. No problem having a tube axle - Land Rover made them for the ultra rare 2WD versions. Might be better to use a later Disco II front axle as it has ball joints. Paul H
Mar 26, 2013 13:18:00 GMT
A Bentley 6.75 turbo V8 engine and box Mwaa haaa haaaaa! That's properly mental! Love it. Twin turbos would be even better! A rangy axle would probably do he job - over finch nail big Yanky V8s to them without issue and they're plentiful. Itd need spring pads and a little narrowing though.
Koos
stefan
Mar 26, 2013 19:43:58 GMT
Well I can start trying to tune it once its in and running
stefan
Mar 27, 2013 17:33:19 GMT
So how strong is the Volvo 1310 axle?
A Bentley 6.75 turbo V8 engine and box Mwaa haaa haaaaa! That's properly mental! Love it. Twin turbos would be even better! A rangy axle would probably do he job - over finch nail big Yanky V8s to them without issue and they're plentiful. Itd need spring pads and a little narrowing though. Don't think so. The Range Rover is permanent 4 wheel drive so power is being fed out to both axles. Plenty of people break standard Land Rover spec diffs with unmodified engines but plenty of abuse. I cannot imagine that a Bentley Turbo engined one would not be given generous amounts of abuse whether 2wd or 4wd. As others have said go american and get it narrowed. Plenty of ratios available for most of them. Adrian
Vitesse 6 Saloon Vitesse Mk2 Convertible BMW R1150GS VW Amarok
stefan
Mar 29, 2013 20:42:45 GMT
Will not be using anything by the rover group, think it will have to be yank, and strong yank at that
Mar 31, 2013 13:54:29 GMT
Why not just mod a Bentley one to fit ? Could you not use a Jag axle?
Onne
Mar 31, 2013 15:19:32 GMT
Needs to be live at a guess. Which neither of those are
stefan
Mar 31, 2013 21:09:00 GMT
I wish to retain the leaf springs so want a live axle in the back and a beam up front
stefan
Well just won a pre narrowed Oldsmobile O series axle with range rover discs and mg metro 4 pot calipers on.
That's one problem out of the way, its amazing how many problems you encounter putting a massive engine into an 88 ince leaf sprung Land rover.
skoze
I really, reeeeeeeally want to see this!
stefan
It will take a while yet still collecting bits to make it all fit togeather
