kevfromwales
Apr 13, 2013 13:12:43 GMT
we've got an iveco derv tank that may well be suitable, it's plastic and fairly retangular, so should be easy to mount, wherever we choose
sorry to hear about that phil, maybe fuel tank location might be the one sensible part of the build...
LowStandards
Apr 13, 2013 16:11:48 GMT
I reckon a behind the seat type affair would be ideal, off an old merc or summat. The boots gotta be big enough still for many many many beers...
Apr 13, 2013 16:49:31 GMT
XJ40 has a "behind the seat" fuel tank.
Paul H
Apr 13, 2013 16:51:00 GMT
Mini fuel tank? Small... easy to fit and running a derv its only gonna use the fuel outa the filler neck anyway...
bl1300
Apr 13, 2013 18:45:44 GMT
[student] Ah ive got it! put a suitably sized tank full of beer up front in the gap between radiator and engine, possibly even plumb up said tank to a second radiator with a pump to circulate the beer aroun and keep it cold [/student] ewww warm beer. Oh wait you say fit a cooler for the beer ;D What about using something like a spitfire fuel tank that sits right behind the seats normally is pretty rectangular so should be easy to fit.
Current fleet.
LowStandards
Apr 13, 2013 19:10:01 GMT
You should of kept the door in the washing machine used for the boot floor, could of used it as a fuel bowl ;D
Apr 13, 2013 23:47:28 GMT
fransit tank under boot floor? even comes in diesel flavour.
theres more to life than mpg & to much power is just enough.
kevfromwales
we have a few tank options fellas it's not so much 'what can we use' - it' a case of having the worlds biggest engine bay, and the iveco filling less than half of it LOL - think we'll have to look further into the beer cooler / still options
Chrisâ„¢
This is clearly filler material.
Hmmm... how about two Iveco engines? Just to fill the space up a bit more...
1989 Volvo 340 1986 Suzuki SJ413 2000 BMW 318ti 2006 Lexus IS250
Club RR Member Number: 160
Hmmm... how about two Iveco engines? Just to fill the space up a bit more... One to run the transmission to drive and one to run a compressor for the air ride
Hmmm... how about two Iveco engines? Just to fill the space up a bit more... One to run the transmission to drive and one to run a compressor for the air ride ...and the beer refrigeration plant.
Apr 16, 2013 20:43:48 GMT
Hmmm... how about two Iveco engines? Just to fill the space up a bit more... What about 1 engine and a humungous turbo! Hang on what about a wood gas plant in the space for even cheaper running?
Last Edit: Apr 16, 2013 20:44:28 GMT by dodgerover
Apr 16, 2013 21:29:46 GMT
Last Edit: Apr 16, 2013 21:38:47 GMT by chairchild
Apr 17, 2013 13:22:01 GMT
THIIIIIIS^^ !!!
Apr 17, 2013 13:30:57 GMT
Be a bit pointless on a derv lol, you'd have to have a gearbox in there to get the rotor rpm up.
Beer storage might be an option, i've got some kiln lining that I could do a firewall with, then just have some mounts to put those 12v cool boxes under there.
Apr 17, 2013 14:52:04 GMT
BIGGER IVECO ENGINE!!
Apr 17, 2013 16:41:41 GMT
I reckon you could fit a truck size one in there, but its not in stock and therefore won't happen haha.
Apr 17, 2013 17:04:25 GMT
gunner seat under bonnet FTW, photoshop of wooly-hatted northerner in gun turret required ASAP !
rysz
Apr 17, 2013 17:14:33 GMT
gunner seat under bonnet FTW, photoshop of wooly-hatted northerner in gun turret required ASAP ! This is the winner! Rysz.
Apr 17, 2013 19:40:54 GMT
could always put a novelty "child seat" in the gap?
Safety first and everything....
Last Edit: Apr 17, 2013 19:41:46 GMT by chairchild
