Apr 12, 2013 12:52:50 GMT
this bomber has been languishing in a shed at my nans for 25 odd years. it used to be my uncles when he was a teenager and I used to use it when I stayed at weekends, nan recently moved and we are clearing the out buildings. there's a fair bit of nostalgia and sentimental value surrounding this bike, said uncle died many years ago and I don't actually have a bike, so decided to save it from going in the skip and recommission it. I owned a striker followed by chrome burner in the 80s so I was quite envious of this bigger bike, and with gears ! if I remember back the bomber had a certain demographic, sort of doc martins, shaved head "hard kids", which I am not but beach cruiser/ 1950s klunker styling is very much en vogue at the minute the bomber was stored in a draughty old shed, so while its not had direct water contact, its had a fair bit of "humidity" !! everything is free and working (including the 3 speed sturmey) my main concern is that the chrome parts are in bad shape, down to the steel on parts of the rims. the other issue is decals, they are faded and hanging off, but I've found somewhere that does sympathetic reproduction in vinyl the rear hub is dated november 1981, and the frame number relates to september. I like the period features of the ever-ready lamps and the weird brush things around the hubs which I remember were luminous
Last Edit: May 17, 2013 10:37:59 GMT by darrenh
Apr 12, 2013 12:54:36 GMT
i had a little go with some fine wire wool and engine oil which didnt turn out too well, and following some ridiculous quotes for re-chroming i think some new rims are on the cards
Apr 12, 2013 13:00:22 GMT
Em
Fuel Injected? Carb Infested!
Apr 12, 2013 15:36:13 GMT
Blimey, not seen one of these for decades!
They were kind of the missing link between BMXs and Mountain Bikes...
Didn't they have a picture of a Hercules (or similar) on the top tube?
Good luck with this!
Apr 12, 2013 17:25:17 GMT
thanks mate, yeah they had a bomber leading the word "bomber" along the top tube, and WWII style search lights along the bottom tube and seat tube
Smiler
I no longer own anything FWD! Or with less than 6 cylinders, or 2.5ltrs! :)
Apr 18, 2013 21:56:37 GMT
Cool bike, hope you get it up together.
www.Auto-tat.co.uk'96 Range Rover P38 DSE (daily driver) '71 Reliant Scimitar SE5 GTE 3.0ltr Jag V6 Conversion '79 Reliant Scimitar SE6A 3.0ltr 24valve Omega Conversion '85 Escort Cabrio 2.0 Zetec - Sold '91 BMW 525i - Sold '82 Cortina 2.9i Ghia Cosworth - Sold '72 VW Campervan - Sold '65 LandRover 88" - Sold
Apr 19, 2013 15:32:48 GMT
thanks not much to update but did get a set of reproduction decals from retrospectbmx.com
Last Edit: Apr 19, 2013 15:33:15 GMT by darrenh
Apr 19, 2013 17:04:44 GMT
Brilliant that, can't wait to see it when you've restored it.
Corsa Apology Champion 2014.
Apr 20, 2013 15:08:04 GMT
thanks H so as threatened i made a start stripping down the R-Bomb. this pic is undoing the rear hubs nuts and taking the gear cable out after getting the back wheel off and unbolting the rear eveready lamp i thought hmm that feels a bit heavy, like batteries still in it heavy. slide the cover open and found period batteries unfortunately as you can see one had leaked and the contact from the lamp has fused to the top end, which then snapped off. so this lamp is scrap but will keep for spares wheel off, mudguard off and the rear forks removed. at this point i noticed two snapped spokes and the offside fork is bent. well they did call them action raleighs, and my uncle wasnt shy finding huge ramps lol front wheel off, both crank cotter pins removed, plus crank and pedals the crank pin was quite notchy so i decided to go deeper and undo the bearing adjusters, any tool kept slipping off the shallow shoulders so i just tapped it round with a drift crank pin slid out and looking through to the bearing track on the offside (after cleaning it out). the track looked removable in the same fashion, but was well painted in so left it. crank pin, bearing track and ball bearings cleaned up. they came up spotless so i'm guessing it was just dry old grease and grime making it notchy. note to self, 22 ball bearings i counted, 11 each side. then i cracked off the handle bar adjuster, hooked the forks over the garden fence, applied wd40 and turned, DINK, it came free (phew) the expanding joint is free and clean here ive taken off the fork locking nut and lamp bracket, then undone the top bearing track then caught the top ball bearings in a container. never throw away your old chinese cartons !! then i slid the forks out and caught the bearings from the bottom. another note to self, 25 ball bearings came out top and bottom, 50 total. then i drove the bearing tracks out of the frame, and the one off the forks. everything cleaned up shiny despite starting off a bit brown, so big relief there. final pic for today, everything except the wheels laid out. i'll probably unlace the original rear wheel later, or tomorrow.
Deev8
Apr 20, 2013 15:18:43 GMT
Fantastic i had forgot about these what a great build. The best of luck with it.
Just rolling along
Apr 20, 2013 15:23:59 GMT
drive side bottom bracket cup is a left hand thread BTW pop down your LBS with one of each bearing, you'll get a new pack for about a quid each size.
Last Edit: Apr 20, 2013 15:25:12 GMT by welshpug
Apr 21, 2013 16:33:28 GMT
thanks to you both couple of pictures today, i heat gunned the decals off, rubbed all the frame parts down with 400 grit w+d. there were also a few splits and dents in the paint where the rust had ferreted around underneath, i had to bare metal them with the strip and clean disk then etch prime those bits. then i busted out the compressor, gun and the black gloss, thinned it down 2:1 and did a coat every 15 mins not a bad shine straight out of the gun. will do a wet flat with 1500 and polish it after, to get the flies out
dungbug
'Ooligan!
Apr 22, 2013 17:56:03 GMT
Fantastic thread, I remember a mate of mine having one of these when the rest of us had Burners....Wish I still my old Burner.
Past: 13 VW Beetles from 1967 - 1974 Bay Window Campers (1973 & 1974) Mini's (1992 Cooper lookalike & 1984 '25 Anniversary) MK2 Polo Coupe S (1984 & 1986) MK2 Polo Breadvan (1981 & 1984) MK4 Escort (1989) MK2 Granada Based Hearse (seriously) Fiat Uno 60S (1986) Punto 60S (1998) Cinq (1997) 1998 Yamaha YZF600R Thundercat 2003 Ford KA
Current: 2004 Ford Focus (barely alive)
MK2VR6
Mk2 Golf GTi 90 Spec
Apr 22, 2013 18:03:30 GMT
I somehow missed Raleigh Bombers along the way. Seen a few of them on tinternet latterly, and love the look of them. Cool story associated with this one too. Looking forward to seeing the finished product.
Apr 22, 2013 18:47:08 GMT
burners ? i had a mk1 grifter brand new from the factory, at cost minus staff discount well we are local. i didn't have a bomber cos they were too big for little 9 year old me.
ems1
Club RR Member Number: 5
Apr 22, 2013 19:28:05 GMT
I've still got my blue/chrome bomber in the shed, think it's 31 years old. When I got a car I let my brother use it, so the paintwork is now scratched & chipped. It has rusted over the years but still works. Only bits I'm missing are the foam grips and red bar ends. Nice to see one getting restored.
1985 Manta GT/E 16v 2001 VW T4 Caravelle
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Apr 22, 2013 19:31:16 GMT
Coming on well.
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
mungo
Apr 22, 2013 20:43:55 GMT
I had a bomber!!!.....I wasn't a hard kid though....my dad made me have mud guards on mine to....must have been mid 80's . I think it look just like yours. Were the blue ones earlier or later??
56' bug 2332 +ida's 56' lowlight ghia 72' bus 1600 devon 67' type 3 square - gone 83' gti - gone 90' gti 16v - gone 82' chevette - gone 70' GP1 Beach buggy -gone 78' lightweight landrover 3L v6 -gone 89' gti - gone 83' gti - gone
thanks for the comments. the blue ones were/are called called super bombers quite rare i'm sure they did a super grifter in the same style. i think the rarest are 5 speed version of the black bombers,
Apr 26, 2013 16:57:45 GMT
mini update, the NOS rat traps and cotter pins arrived. quick question (shouldve paid more attention) but i notice the main crank pin is longer on one side, i assume that's the sprocket side?
