1970 herald 13/60 hard top project £(400)
stored near market rasen
lot of work has been done...
photos all on here
club.triumph.org.uk/cgi-bin/forum10/Blah.pl/Blah.pl?m-1358119917/
or on here
s103.photobucket.com/user/green_countryman/library/TRIUMPH%20HERALD?sort=2&page=1
here I have a 1970 triumph herald 13/60 with Webasto sliding sunroof
been stripped down to bare chassis and chassis repairs almost done(see pic)
all suspension parts cleaned and painted and loosely bolted on for moving the rolling chassis with body on top
lots more cleaned and painted has been done
brand new parts list (not second hand/used parts)and many new parts have been fitted
REAR WHEEL BEARINGS Bearing Kits x2
REAR TRUNNION KITS X2
FRONT BRAKE CALIPER SEALS KIT
GEARBOX MOUNTS x2
ENGINE MOUNTS x2
Tread plates x2
UPRATED CLUTCH & MASTER CYLINDER one each
REGREASABLE TOP BALL JOINTS X 2
REGREASABLE TRACK ROD ENDS x2
FRONT&REAR SUSP. BOLT SETs x2
FRONT & REAR BUSH SET - POLYURETHANE orange
FRONT AND REAR BRAKE HOSES
FRONT PADS
HEATER PIPE SET
SIDE RAILS x2
FRONT N/S OUTRIGGER
REAR O/S OUTRIGGER
Distributor SET
HT LEADS
new old stock decoke set
8x steel wheels with tyres and 2 spare tyres
head has been taken off for decoke set to be fitted
water pump+ housing has been cleaned and painted so ready to fit to engine when decoke set has been done first
gearbox has been washed and now ready for painting
engine will be cleaned soon and photo's post
all parts there as there's plastic containers full of all the parts/nuts/bolts/screws
photos all on here
or on here
GEARBOX MOUNTS x2
ENGINE MOUNTS x2
Tread plates x2
FRONT PADS
HEATER PIPE SET
SIDE RAILS x2
FRONT N/S OUTRIGGER
REAR O/S OUTRIGGER
Distributor SET
HT LEADS
