Apr 19, 2013 17:30:46 GMT
What I need is a picture of wireing in the boot from the fuel pump relays fuses and battery,someone wired a permanent feed from the battery to the fuel pump for a reason that has now been sorted and in trying to get it back to normal so I don't have to keep going to the boot to connect it up.can't seem to sus it out! Thanks Paul
SPOTS MUSH!
squonk
Apr 19, 2013 19:26:18 GMT
I've got both a saloon and an estate. I'll see what I can do tomorrow for you.
Apr 19, 2013 22:50:30 GMT
Cheers mate that would be great if you could..no amount of google searching has helped!
SPOTS MUSH!
Apr 20, 2013 23:11:34 GMT
bump
SPOTS MUSH!
squonk
Apr 21, 2013 21:00:13 GMT
Not sure how much help these are as the wires disappear into a loom behind the arch trim, but here you go: You would probably be better off using a wiring diagram.
Apr 21, 2013 22:44:21 GMT
thanks mate thats a bit of a help,its actually the wires that go from the positive battery terminal to under the plastic lid where the fuel pump is aswell that i need.i don't expect you to tear your car apart but if you do feel like it then that would be great!lol
SPOTS MUSH!
squonk
This ones not at my place but I should be back round to where it is stored later this week so I'll see what I can do for you.
