I bought this back in 2009 and it's not really had the use I thought it would. I've weighed up the space taken/amount of use/need for money ratio and decided it's probably best to sell it.
It's not the prettiest of things, but it's a damn good sand blaster and that's what matters.
It comes with a foot pedal controlled blast hose/nozzle with proper fittings so just needs connecting to a compressor and you're away. The hopper is huge and will hold a LOT of blast material...and it has a hinged hatch at the bottom for very easy emptying.
It has a large side opening door (the whole side hinges), it has very good internal illumination and best of all, proper extraction via some fans and filters at the back. As said, it's a proper industrial type blast cabinet, not a little hobby one.
Capacity wise, it'll easily take large (18") wheels with plenty of room to move them around once the door is shut. The size makes it ideal for blasting all sorts of things from rocker/cam covers to suspension components to wheels and pretty much most things to be honest.
PhotoCOCKet has decided to kill some of the photos I'd uploaded, so I'll try and take some more when I can. Apologies about that (I've already deleted them off my phone) but hopefully these give you some idea?
£200 - collection only from Bristol (I can deliver locally within Bristol or slightly further afield if my fuel costs are covered). Look at the price of hobby ones and you'll see this is a superb buy for its size and spec.
