Here is my Nissan Skyline R33 for sale. I am selling it because I need to raise funds for travelling.
Tax: 31/10
MOT: None but should go straight through!
It has an N/A RB20E engine which is the 6-cylinder 12v 2.0L single cam (cheap to insure - try skyinsurance for quotes). Engine mods are electric fan (manual switch), high-flow air filter, removed air con belt (no a/c) and what I think is a 4" cat-back system (sounds awesome!). Note that the clutch is very sensitive/light and gets a bit of getting used to. I changed the engine oil and filter roughly 1000 miles ago with good quality brands and the correct thickness oil. Also had an LSD.
I have fitted a flip-out radio/CD player which can also be used for watching DVDs, it has bluetooth and an aux port as well as a normal FM radio. It can be linked to a sub and the wires are present. I've also fitted a new gearstick gator and knob.
The car itself is an import but it has had the speedo changed to MPH however, the mile-ometer has been disconnected so that it doesn't read incorrectly. I think the actual mileage is 90,000~ kilometers/55,000 miles. Also the rear of the passenger seat has a slight rip.
It has black 18 inch Nismo wheels with a decent amount of tread on massive tyres, apparently they're worth a bit of money!
The car will come with a new dished steering wheel and boss kit to fit (pictured). It cost quite a bit! There are also spare wipers included.
Recently I've had some surface rust treated with waxoyl in the valance, front arches and boot (pictured).
The battery has been moved to the boot because it was originally going to be a track car (better weight distribution). The battery is clamped down and the rest of the boot has been stripped-out.
Unfortunately one of the previous owners has put stickers on some parts of the car and it has damaged the paint upon removal, the only noticeable bit is by the fuel filler.
The car was involved in a minor accident with a previous owner which is why it has a black bumper and bonnet. I think it looks good but it's up to the buyer if they want it sprayed. The O/S front wing was also changed at this point and someone tried spraying it with a rattle-can to match the rest of the car (matches well), unfortunately some of it has started peeling off.
The only real issue with the car is a minor misfire when cold for the first minute but it goes away very quickly.
£800 OVNO! I paid close to this amount for it in worse condition!
Located in Dorset/SP7.
Contact Toby on 07979797070.
Tax: 31/10
