Ford Sierra P100 Pickup truck with tax till end of July and mot until august
As you will see from the pictures the vehicle has been modified and is by no means a standard truck.
The engine is a 1.8 turbo diesel which runs very well and is more than adequately powered for the truck which pulls well even with a load on the back. The truck has a straight through exhaust and a pipercross airfilter fitted ,
The suspension has been lowered and the truck sits nicely on a set of genuine cosworth 15inch lattice wheels, 2 of the tyres are new. The truck is fitted with a mk2 escort rear axle and has been converted from 5 stud hubs to 4 stud hubs from a 2ltr sierra as are all of the brakes,
On the outside of the truck it has been fitted with a genuine cosworth 4x4 bonnet , grill and front bumper, the tailgate and rear window have been modified to give them both the smooth look .
Inside the cab has also been updated to a sierra cosworth dashboard,fitted with turbo boost guage. fiesta RS Recaro seats, and a 3 spoke Cosworth steering wheel.
The truck has had a new battery fitted a few months ago aswell.
The P100 is a nice truck but does have a couple of faults that do need sorting out, I have too many other projects and don’t use the truck as often as I would like hence the reason for sale .
The main issues to note with the truck are as follows:
The interior is a little tatty and could do with a good clean and tidying up, the instruments on the dashboard do not work ,the speedo does however work as it should. I believe the dashboard could do with rewiring properly as everything not working is electrical and also the headlights are dull ,other than that maybe put a standard dashboard back in to it?
Another issue to note is a slight wobble when braking which is down to the rear brakes being warped, I will supply replacement brand new drums with the truck which alone cost me £80 .
tel 07825 021 429
WILL POST IMAGES TOMORROW
tel 07825 021 429
