That's nice. The only thing that looks off to me is the front wheels could do with being a bit narrower to fit the arch, I don't think the arch should be out any further than it is. The front lip and new sill profile is nice too. It all fits the proportions of the car nicely, when done it'd look almost factory I think. don't worry, wheels are for mock up only, proper wheels will not be sticking out like that on the front
Hello Tony , Don here. Proportions look good . I was a bit unsure of the ET20 offset on the fronts thinking that the E36 versions of the RC090's would sit better but that would give a staggered look which I don't think would suit. If the fronts are going to match the rears then the arch depths are spot on . It'll look tough ...........
Looks about spot on to me, very nicely proportioned and fit nicely with the lines of the car.
first reaction, looks a bit like the nicholas cage spec "eleanour"
two thumbs fresh
Oct 27, 2013 19:02:36 GMT
Oct 27, 2013 19:34:01 GMT
Watching this thread after recently re-reading the epic victor thread and looking for any help, inspiration and anything else needed for my wheel arches and inner and outer sill.
Oct 28, 2013 12:25:04 GMT
got a genuine tech question for you tony ! butt welded changes in profile on bodywork
i've done the same a few times, similar situations with overlapping spot welds. i get full penetration when viewed from the rear, however when i grind the welds back roughly, then flap disk and then DA so its a perfect smooth invisible finish, every now and then i get a hair line join re-appearing between the two separate bits of metal and i have to go back and re-tack it and dress it again. just wondered if you have any pearls of wisdom, at face value it doesnt make much sense as the welds appear to have gone full thickness
Oct 28, 2013 16:44:47 GMT
I can only smile in approval.
You really are an inspiration mate.
Looks great so far.
Oct 28, 2013 17:10:09 GMT
got a genuine tech question for you tony ! butt welded changes in profile on bodywork i've done the same a few times, similar situations with overlapping spot welds. i get full penetration when viewed from the rear, however when i grind the welds back roughly, then flap disk and then DA so its a perfect smooth invisible finish, every now and then i get a hair line join re-appearing between the two separate bits of metal and i have to go back and re-tack it and dress it again. just wondered if you have any pearls of wisdom, at face value it doesnt make much sense as the welds appear to have gone full thickness Darren That does sound odd, as that is certainly a symptom of not enough penetration, the only other thing I can think is that it is getting so thin and hot that the weld is then cracking, but you would soon realise that when you try to weld back over it, and you would blow through Its got to be penetration I can only smile in approval. You really are an inspiration mate. Looks great so far. Thanks Grizz
PhoenixCapri
West Midlands
Club RR Member Number: 91
Oct 28, 2013 21:55:08 GMT
Wow that's going to be stunning, want your workshop as well!
jules
Oct 28, 2013 23:03:16 GMT
got a genuine tech question for you tony ! butt welded changes in profile on bodywork i've done the same a few times, similar situations with overlapping spot welds. i get full penetration when viewed from the rear, however when i grind the welds back roughly, then flap disk and then DA so its a perfect smooth invisible finish, every now and then i get a hair line join re-appearing between the two separate bits of metal and i have to go back and re-tack it and dress it again. just wondered if you have any pearls of wisdom, at face value it doesnt make much sense as the welds appear to have gone full thickness Had exactly the same as you say, 'very fine hairline cracks' when flap disked butt welds smooth. Nice to know I'm not the only one, but would be nice to know where going wrong !
Ian
Oct 28, 2013 23:06:29 GMT
Amazing work as ever, looks seamless, which is the intention! I have set of the narrower BBS wheels on my e36, would happily swap you a narrow pair for a wider pair to get the staggered look! Missing the AL-W 535 updates, but the celica is a worthy alternative.
bstardchild
Club RR Member Number: 71
Done a bit more on the Celica, I'll not go into too much detail here, as I'll add the how too, to the Making Panels thread After fully welding, and grinding, and a whizz over with the DA Stunning - make with the how to thread stat............ Brilliant work so impressive
jpsmit
stunning - I am so impressed!
eurogranada
How could I have missed this... Very nice work there. Shapes are ace, finish top notch as well... just wow!
Nov 10, 2013 19:58:08 GMT
Nov 16, 2013 22:50:25 GMT
Front Arch almost finished, just need to make the bit that runs into the front valance
Nov 16, 2013 23:02:58 GMT
Those arches are a work of art
rodney
Nov 16, 2013 23:26:52 GMT
awesome workmanship
Nov 18, 2013 16:53:49 GMT
Ah this is where your hiding seems a bit silly me posting your work on my thread so i will wait till your finished then start up my thread again
