Hope my winter runaround is retro enough for here! The other day when I started the car it had a bit of a plasticy sounding clattering noise for a few minutes after starting that soon stopped. When I got to work it stalled (first time it had ever stalled on me) as I was pulling into the parking space and didn't start nicely at all - it turned over quite a lot before spluttering into life.
I drove it home and it had the same noise on start, and again stalled at low revs when parking. There was an odd smell, a bit like hot transmission fluid or something. Tried to start it today to put it on the drive to check it over, but it's not even starting now. Wondered if the clattering noise was the lifters or something so checked the oil - it's low but not below minimum, but in the filler cap it is very black and sludgy with bits. Took the cam cover off and it looks like the gasket plate has shed it's coating?
Pictures don't really show it well but it's coming off in big flakes
Also took out the spark plugs and tried turning the engine by a socket/breaker bar on the crank - it wouldn't budge. Thinking maybe all this crud floating about has blocked an oilway and cooked a bearing or something? Any thoughts/ideas?
