Just doing a bit of research for the time being, but it's hard to get much of an answer with only a bit of mild googling. What I'd like to know, is how complicated is it to get a cam regrind, if your cam's never been done (ie: nobody's ever done one for your specific engine) I'd be looking at getting the base circle reduced, to give an effective 1.5mm extra lift (or thereabouts) but I've got no idea of how much to expect to pay, will they be ok with just the one cam, or do they sometimes need a "donor" cam to chop up first to test for hardness thickness/etc? Any info is greatly appreciated! Have a pic of a knackered vw camshaft as payment!
v8ian
I have had cams made for me by Newmans, and many many years ago I used to get reground Pinto kits from them for not a lot of money, Its worth giving them a call. www.newman-cams.com/
rodney
i was going to sugest newmans , they seem to have a good reputation,.
Kieran
I've had cams done by Autosprint in Birmingham before for about £90.
Very reasonable, friendly and knowledgeable.
Also had a Ford Crossflow grind fine on a Skoda cam so you can swap and change.
Give him a ring for a chat.
Last Edit: May 5, 2013 22:58:14 GMT by Kieran
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
Cam regrindsstealthstylz
@stealthstylz
Club Retro Rides Member 174
If they haven't done one for that engine before you usually have to send them one FOC to do a test run on to see how much they can regrind it by.
cheers everyone - will throw some emails around later today
I have had cams made for me by Newmans, and many many years ago I used to get reground Pinto kits from them for not a lot of money, Its worth giving them a call. www.newman-cams.com/Another vote for these guys....they did a high lift cam for my 2286 Land rover lump. Pretty sure that was a one off!! ;D
Koos
steed
Auto sprint knock me up a set of 290 duration high lift cams for my toyota 4A-FE engine, with only one set did it for a good price too think it was around the £90 and the turnaround was good too. Unfortnately i hed a set of custom shims made by arrow precision to my spec (shims were amazing) and being hardened steel they ate through the original soft cast cams although the chap at auto-sprint did warn me that might happen as he thought they were very soft. (also said he never wanted to see another set of 4A-FE cams ever again!)
ovimor
North East
...It'll be ME!
£90... I'd take their arm off!! Anyone had anything re-ground for the SOHC D4F Clio... as in my PROTON SAVVY, too OVIMOR
Knowledge is to know a Tomato is a 'fruit' - Wisdom, on the other hand, is knowing not to put it in a 'fruit salad'!
