roybo
Jun 19, 2013 21:49:26 GMT
I love those cars, shame Opel didn't make a rebadged version for us landlubbers in Europe. Don't know how much you had to grind to get that weld looking like that, but as a finished repair it looks great for a first try. Why'd you weld up the trim holes? Going for no trim or are you going to attach the trim using glue later? done a fair bit of grinding then touching up the weld but was only an hours work or so.... to be honest i'm not a fan of trim etc like a smooth look, also it had already been took off , the ones on the sills had caused water to get in the sills and had gone crusty where they attach the ones on the doors had let water into the door bottoms but luckily only surface rust
1975 vauxhall magnum 1800 work in progress
Jun 19, 2013 22:08:53 GMT
Sounds like you're well on the way to getting all the bits together for the Saab conversion, Nice one!! I'll be keeping a close eye for any updates. Some NG900's rust nicely on the front inner wings, behind the struts. The wheel arch liner rubs against the metal panel, then moisture does it's bit and then, rust!! So you should be able to pick up one for it's running gear pretty cheaply.
1964 Saab 96 two Stroke 1971 Hillman Avenger 1500 GL (Tuned 1600 fitted) 1976 Saab 99 2dr EMS (Project of very slow progress) 1978 Saab 99 2dr EMS (Awaiting reshell) 1981 Saab 99 2dr Turbo (Awaiting reshell)
Jun 20, 2013 15:59:32 GMT
I love those cars, shame Opel didn't make a rebadged version for us landlubbers in Europe. Don't know how much you had to grind to get that weld looking like that, but as a finished repair it looks great for a first try. Why'd you weld up the trim holes? Going for no trim or are you going to attach the trim using glue later? done a fair bit of grinding then touching up the weld but was only an hours work or so.... to be honest I'm not a fan of trim etc like a smooth look, also it had already been took off , the ones on the sills had caused water to get in the sills and had gone crusty where they attach the ones on the doors had let water into the door bottoms but luckily only surface rust Ah, I understand. Know exactly what you mean, my car is blossoming around all the trim holes too. Wondering how I'll go about solving that... Glue maybe, but I'm not sure it'll hold. Not being a trim fan sure saves you some headscratching
roybo
Jun 20, 2013 17:12:25 GMT
Oh yes; i don't care if its original .... i don't want any rosettes
roybo
Jun 20, 2013 17:18:16 GMT
Sounds like you're well on the way to getting all the bits together for the Saab conversion, Nice one!! I'll be keeping a close eye for any updates. Some NG900's rust nicely on the front inner wings, behind the struts. The wheel arch liner rubs against the metal panel, then moisture does it's bit and then, rust!! So you should be able to pick up one for it's running gear pretty cheaply. seen afew go for pennies £200 ..... The gear box from a 3.0 omega was hard to get bagged one in the end for £50 so pleased with that
Jun 20, 2013 21:14:51 GMT
Bargain!! That's the way. Keep up the good work.
