May 10, 2013 10:36:35 GMT
Got '78 series 3 radio van here that I ran around for a while before moving north and also a V8 /LPG classic Range Rover, both are projects and runners but the RR is probably only any good for spares/off roading, can anyone in the know help with values?
Cheers, Ken.
mud
May 20, 2013 11:37:59 GMT
Hi Ken, re the series 3 you'd need to put a few more dets on and piccies would be helpful. Are you positive she's a 78? It might be wort checking the chassis number in case she's tax exempt and worth more. The military stuff registration varies massively. Some leafers were put on later plates as they were registered with their release date rather than build date. I use this forum; ollr.createaforum.com/index.phpThey are far more knowledgable than me! Should be fairly easy to tell about the build date, there's loads of info on the web. If she is tax exempt, I might be interested. As for the rangey, they are on the floor at the moment and probably worth more in bits sadly. Cheers Mud Cheers Mud
