LowStandards
What will this need to pass an MOT? I don't mean the lights and stuff, I mean the lack of doors etc and about the wheel arches, how much do they need to cover the wheel and anything else you can think off...
you don't need doors, but you will need wheel arches which extend as far as the edge of the wheels. Thats my 10 pence worth, I'm sure there are loads more things.
Looks like an awesome project............
LowStandards
So the arches need to stick out past the wheels, but i've heard someone say they only need to cover 40% of the tyre when viewed from the top???
I only need her road legal so i can go green laning
MOT QuestionsDeleted
@Deleted
Feb 23, 2007 10:08:02 GMT
It will need an SVA manual and some head scratching I think
LowStandards
Feb 23, 2007 11:08:48 GMT
Why an SVA? Its a proper Suzuki SJ413, got plates and vins and the like. Not modifying the suspension or owt, still original bodyshell, just cut down a bit???
Feb 23, 2007 11:56:43 GMT
Its got a modified chassis, non standard axles and rear suspension, I'm pretty sure you need an sva, alot more work involved than getting an MOT.
Paul
Mr S
10-4 Good buddy.
Feb 23, 2007 16:22:04 GMT
Mr S
10-4 Good buddy.
Feb 23, 2007 16:24:50 GMT
Quick search by someone with a mk1 golf revealed that...
Hi.
Part of the MOT is to check to see that the wheels do not foul the body.
Normally a wheel/tyre goes inside the wheel arch when the suspension is compressed. A wider tyre /wheel may cause it to foul the body work.
If the front tyres foul the inner arches or similar on full lock that too is a failure.
Other than that I can't sea any problems MOT wise.
Kev
Wheels protruding beyond the arch is illegal but not part of mot (sure ive written this before)copper shud have done u for breaking construction+use regs,not blamed mot.
Mr S
10-4 Good buddy.
Feb 23, 2007 16:28:12 GMT
Also
Doors removed is not a reason for failure - except for tailgates / dropsides / loading doors / boot lids. These 'must close securely'.
Rootes Member Hi All,
about a year ago I bought a little sprint car (Clan Crusader)
It is stripped out, no passenger seat etc..
you can not open the passenger door from the inside as the latch is faulty - has been for some time.
still trying to source a new lock.. spoke to previous owner and he used to MOT the car at the start of the season but used to take the doors off prior to the MOT.
so is it acceptable to remove the doors before taking the car to the test centre? this would give me more time to secure a new latch mech and still get an MOT
Regards
Si
Feb 23, 2007 16:37:48 GMT
wont need an sva for non standard axles or engines, thats just a nasty rumour, you have to drastically alter the appearance (ie new body shell not removing stuff or adding arches) or move the location of the engine before you have to worry about SVA tests.
you might have trouble getting an MOT because of sharp or hard bits on that though. ie the roll cage.
you should be able to get a ticket with only side lights and brake lights as well (and fog light if the thing is new enough)
easiest way is to find a friendly garage and see if they'll do you an MOT pretest for a few quid. get a list of what it'll need and then take it back to them for the ticket.
Feb 23, 2007 16:51:12 GMT
wont need an sva for non standard axles or engines, thats just a nasty rumour, you have to drastically alter the appearance (ie new body shell not removing stuff or adding arches) or move the location of the engine before you have to worry about SVA tests. Classic bloke down the pub stuff
Mr S
10-4 Good buddy.
Feb 23, 2007 17:07:31 GMT
Isn't there some kind of points system now, where altering the chassis will attract so many points, changing axles will get some more points etc. and if you go above a certain number of points you have to take an SVA test?
Feb 23, 2007 18:03:05 GMT
Just had another thought about the arches, "lardyforehead" had a moonbug beachbuggy and that had wheels protruding so you might be right.
So far there have been all sorts of varying opinions, you had best take it to an MOT station as suggested and find out.
froggy
Feb 23, 2007 18:46:12 GMT
if you brought it to me to test other than covering the wheels and having front and rear side lights ,stop lights,washers and wipers,horn i would test it as long as the vin was present
Feb 23, 2007 18:55:29 GMT
IT DOESNN'T FAIL ON THe wheel arches, but tis illegal. sharp edges are ok if not corrosion/damage. also you can take the front screen out. 8)
Feb 23, 2007 18:58:29 GMT
you've got no o/s mirror. mirrors are an age thing but id guess yours is to young.
wheels and tyres can stick out past arches as long as the actual tread is covered, as has been said its not an mot fail, but you will get pulled over in ten seconds flat without arches.
