May 23, 2013 10:35:54 GMT
Has anyone done it? I'd love to get mine lower but coilovers are £700 and the car is worth about that but E39 ones are £200.
Some one mentioned it on here and I've googled it but only found the usual you'll kill nuns carrying kittens type answers
Thanks
Adam
May 23, 2013 13:38:42 GMT
I've planned to do the same. The main difference (apart from the obvious spring and dampers rates etc) is that the front ARB attaches to the damper body on the e38. If you're just after maximum lows on a beater you can run without the arb, but I'm planning to make a pipe that slides on top of the damper body with an arb mount and is keeped in place by another nut on the threaded part. Another solutions is to get coilovers with removable inserts and weld the ear to the body. You can obviously try this on the non-removable-insert type too if you're feeling fearless ;D
The rear should fit straight on.
Last Edit: May 23, 2013 13:39:46 GMT by dude
Bolf
soooooo , Did this happen? i've got a manual v8 e38 now and want to replace the worn coilovers
I've got the coilovers sitting in the garage, haven't had a chance to try them out yet though.
Bolf
Let me know dude , if it works i'll buy some E39 Hsd's and adapt.
