Hey guys, was going to fit this to my Escort but I've had a change of plans. The downpipe section is all made from stainless steel, 2.5" downpipe with 1.5" Wastegate takeoff, this bolts to a 38mm Wastegate that i was told had a 14psi spring. 1.5" slash cut dump tube is bolted to that. The piping and flange is all new, never been used, but the wastegate has seen some use. Some marks on the anodising, came in a turbosmart box but it's not a turbosmart WG, some spare flanges in there too.
5 bolt stud pattern to fit Escort RS Turbo T3's, however if fitted to an RS in the standard turbo position the downpipe points towards the bumper. I was going to have a front exit exhaust but you would either need to cut and reweld the pipe to suit the standard exhaust system, or make some additional tubing to fit.
Turbo in picture is NOT included
Looking for £85 collected or £105 posted, its a heavy piece of kit and will be sent via courier. Located in Palmers Green, North London
Cheers
Cheers
