Aug 19, 2013 19:35:14 GMT
Bit of an update… Dents dents and more dents….. Before After Damage. Repaired, My latest e-bay purchase……..Carlos fandango tail pipe……init…..lol Also decided to put a hinged panel in the one side for viewing purposes at the beach ha ha And now the good news….. The mechanical side of this project is about to start. (and about time) Bought a lowish…. mileage Audi A4 1.9TDI. After measuring the engine and box it should fit in with minimum of cutting. I have been told there is a company in the Birmingham area banding steel wheels anyone have any details…. Thanks Dave
Last Edit: Aug 27, 2013 16:00:54 GMT by hanger18
Aug 20, 2013 10:00:00 GMT
If it helps I had my wheels banded by www.bandedsteelwheels.co.uk/ Damian was great to deal with and the turn round was very quick, picked up on monday and back in my house on friday ! Came back from spain last thursday from Bilbo and there were 3 H vans on the ferry all with british plates one slammed, looked real good,
Play'in round with an old Datsun & a Ford COE
Aug 20, 2013 11:41:28 GMT
carlos fandango showing your age there
Aug 20, 2013 20:41:41 GMT
Message ends
jeth
Aug 21, 2013 11:41:43 GMT
Looking good, but i would install engine from a Citroen Plenty of good diesels in them.
1989 Citroen BX 16Valve 1999 Citroen Xantia HDi
Aug 21, 2013 12:09:25 GMT
Looking good, but I would install engine from a Citroen Plenty of good diesels in them. Been looking for an engine for an hy for 2 years. Ive measure hundreds, as I'm a mechanic and get all makes through my workshop and the garage next door.. The Audi A4/Passat 1.9TDI will go straight in with hardly any cutting and very little modding. The HY drive shafts will fit the Audi box with 2 small adapters. It’s also a proven bomb proof engine. Believe me I did my homework before I started this project or purchased anything. My days of 2 to 5 year builds are over… 6 months now is the way I'm going….. Also as a mechanic I don’t like modern Citroens. Sorry…………..
Sept 7, 2013 20:05:15 GMT
Needing a break from bodywork, I decided to start on the mechanicals. Having no work booked in on Friday I decided to strip the Audi. With help from my 13year old son we decided to strip out the wiring loom first. Every thing was carefully removed and labelled from front to rear. Passed through the bulk head and piled up on top of the engine. Next the engine and box was removed and it was still only mid afternoon. A quick call to the local scrappy and within the hour the body was taken away. Not a bad days work. Thanks Will.. x x x Saturday I set about the wiring, stripping of all the binding. And laying it out on the floor behind the engine. What followed was a horrendous few days of slowly going through every single wire in the loom. Cutting out everything but engine management. As I am no electrician I can honestly say this was the worst and most confusing job I have ever undertaken as a mechanic… This is what I removed. Next I had to decide where in the van I was going to put the engine management. The passenger foot well was decided upon. A piece of wood was cut to that shape and mounted on a pole. Every thing was then squeezed onto this board So today after another nervous/confusing few hours the final wire was trimmed and soldered into place. The engine was strapped down to the trolley, everything checked, double checked and checked again. The key was turned and………… No one was more surprised than me.. The engine burst into life. Inspired by the mornings success I decided to move on to the van.. All the floor around the engine and box is removable. The photo below shows how much access this gives. The front chassis is held in with these 4 long threaded tubes. Remove these, jack the body up and wheel the whole thing out. Suspension, steering rack. Engine, box, Clutch and brake pedals. All in one unit. Damn clever those Frenchies…….
Kev
Sept 8, 2013 11:06:41 GMT
This thread is bloody amazing! Love this van, can't wait for more updates
Sept 15, 2013 12:02:42 GMT
At the start of the week I tried the new engine in the chassis. Unfortunately the turbo had to be removed, Steering pump mount cut off, fuel filter unbolted and Oil filter removed, to get the motor in. Next the engine was blocked up and checked for square in the chassis Then 4 engine mounts were fabricated. With the engine mounted. I had to figure out how to refit the components that had to be removed. First the alternator was relocated under the engine. The alternator is not as low as it looks in this photo. Its well above the scrub line. Next the turbo This would not fit anywhere near it original position. Only cutting the chassis completely away would facilitate this. So this was relocated to the front of the engine. If I had the time I would have fabricated a tubular exhaust manifold but with only limited build time (6 weeks) a quick fix was needed. A turbo mount was made. Turbo mounted and connecting pipe made up. That’s it for another week… Only 5 weeks left now…..HELP ! ! ! ! Sunday morning…. Snuck out for a few hours this morning and removed the EGR valve. Back home for family time………Ha Ha… See ya soon.. Dave.. P.S. nearly forgot. also made up 2 drive shaft adaptors (forgot photo’s)
Last Edit: Sept 15, 2013 12:08:21 GMT by hanger18
Sept 16, 2013 19:45:48 GMT
what an awesome project! good luck with the engine swap
Sept 17, 2013 16:28:04 GMT
Thanks for your comments boys. As you can see from my posts, I'm a man of few words. I tend to let my hands and imagination do the talking…… Dave…..x
Sept 20, 2013 7:29:57 GMT
I'm following this closely, have an H-van waiting to get some love after I finish our house...
great work!
Citroen HY 1962 Toyota CROWN MS75 1972 Toyoya CROWN MS75 1973 Toyota CROWN MS67 1972 Toyota CROWN RS56 1968 Toyota CROWN MS57 1969 Datsun 120a coupe 1975 VW LT31 1995 Volvo XC70 cross country 2007
bstardchild
Club RR Member Number: 71
1964 Citroen HY Van (part 2)bstardchild
@bstardchild
Club Retro Rides Member 71
Sept 20, 2013 18:50:46 GMT
Thanks for your comments boys. As you can see from my posts, I'm a man of few words. I tend to let my hands and imagination do the talking…… Dave…..x A picture is worth a 1000 words - a few words to explain whats going on in the picture make for great threads that everyone can learn from so thank you from someone who is following the thread (bookmarked since end of page 1) and enjoying it as well as finding it educational for my own projects
Sept 21, 2013 8:28:47 GMT
great thread almost bought a HY a few times but the few ive seen were all wrecks What are they like to drive with a standard engine? as I wouldnt have the time or skill to fit a Audi one like yours I guess it cant be any slower than my AMi
Sept 21, 2013 8:49:16 GMT
Holy cow, this is seriosly brilliant. I would have felt like THE DADDY if I had managed to start up that engine first try with it sat on a pallet. Mega impressive work.
Sept 30, 2013 17:56:01 GMT
great thread almost bought a HY a few times but the few ive seen were all wrecks What are they like to drive with a standard engine? as I wouldnt have the time or skill to fit a Audi one like yours I guess it cant be any slower than my AMi Hi. I used the van as parts fetcher for 2 months and it was fun. But as a daily driver, I think it would soon become a bind. Top end speed, mpg, brakes, noise, etc etc. Hence, I'm changing the engine/box and improving the brakes, the other eccentricities associated with owning a classic vehicle I can live with. Dave
Siert
Sept 30, 2013 18:23:46 GMT
This is a great project, good job on improving it!
Sept 30, 2013 18:56:50 GMT
Hi All. With the engine more or less sorted I made a start on the front brakes. With no kit available (to my knowledge) I had to design and build my own set up. I must say a big thank you to Bromsgrove Motor Factors for once again giving me free access to there ware house. This allows me to search there entire stock for the appropriate components. It took 2 days to find the discs I used…………………….. It then took me a further 6 days of head scratching and machining to come up with my set up.. All done with just my old Lathe, Pillar drill and hand grinders. Then stripped the chassis cleaned it up and gave it a lick of paint. Suspension arms and torsion bars where striped, cleaned and freed up in some cases, greased and re fitted. Oh nearly forgot, lowered the suspension by about 3”. Can now readjust suspension ride height in about 5 minutes per side. Discs, hubs and callipers where then assembled for the final time and mounted to the chassis. That’s it for today. Drive shaft rebuild tomorrow. Dave……..
Last Edit: Sept 30, 2013 18:58:58 GMT by hanger18
simes
Sept 30, 2013 20:26:53 GMT
Excellent Project - I've wanted a "corrugated van" HY for years. My dad has a 1958 2CV - the metal is really thin - difficult to weld!
Simes
205Mi16 - 262 cams, Jenvey Throttle Bodies, Emerald managment blah blah...... E91 320D MSport Honda NC30 Vespa 300GTS
Sept 30, 2013 20:48:05 GMT
Great progress! I really like your ideas and engineering. Does the HY originally have inboard brakes just like the DS? I assumed you would've used the audi arms and hubs? And what exactly did you change with the brakes, larger rotors? It's going to be a great car when it's done, keep at it!
