As above, engine has done zero miles since the rebuild, it's the 6 port high power version, was rebuilt by WGT Developments in Cheshire using Atkins seals, etc.
It's been stored indoors in the dry since the rebuild with all the ports blocked and just a little oil run around the rotors to keep everything fresh.
I also have our old tubular exhaust manifold, couple of flywheels, starter motor, uprated coils/leads/loom adapters, and other parts I may let go with it to make it an easier install if someone wants them.
I also have a 36-1 trigger wheel setup if anyone wants to use a standalone ECU on it, and an adapted VW clutch/flywheel/pressure plate setup which will bolt straight on for use with the old VW transaxles.
£1500ono
£1500ono
