Hi folks,
I've been toying with the idea of modernising and upgrading the front brakes on the Hunter rather than trying to get them "as good as new" (ie not very )
Partly as performance has never been up to modern standards and partly as both my usual motor factors are now telling me they can't get pads for my standard setup
Ebay has them, but I'm very tempted to use this as a good reason to update the brakes.
£150 kits are out (and not available), any ideas for using cheap scrapyard or unpopular (NOS Ebay?) parts welcome.
Ideas so far :
keep existing discs, bolt-on newer calipers ?
fit newer disks & calipers ?
Questions :
Are there any bolt-on (readily available & cheap ) options?
Have I missed anything obvious?
Bolt-on would be good, could get the hubs machined to take Sierra disks if needed (see below), would prefer not to do anything to the struts, no idea where to get caliper spaces made up (ideas or prices?)
"Hunters use stock Girling calipers, just like Fords. So, any Capri/Escort/etc upgrade caliper will bolt on."
www.rodsnsods.co.uk/forum/tech-discussion/hilman-hunter-v8-braking-issues-47010
A very neat job (scroll down to post #58), machining the hub down to take a Sierra disk, then making brackets to hold the new calipers
www.turbosport.co.uk/showthread.php?t=159937&page=2
The RR guide to the 4 (!) types of M16 calipers
retrorides.proboards.com/thread/119686/help-identifying-calipers-capri-2
An interesting photo strip & rebuild page
www.buckeyetriumphs.org/technical/Brakes/Front/Front.htm
Ideas, suggestions, or the loan of a pair of modern Girling calipers to size up and try out would all be welcome!
Cheers
Ideas so far :
Questions :
Cheers
