The car is my 1993 C4 Audi 100E 2.0 8v.
Last week it failed its MoT on, amongst other things, a massive split in the exhaust just upstream of the cat and emissions.
Last week’s emissions were:
Fast idle test
CO = 0.36 (needs to be no more than 0.3) Fail
HC = 73 (needs to be no more than 200) Pass
Lambda = 1.083 (needs to be between .970 and 1.030) Fail
Natural idle test
CO = 0.5 (needs to be no more than 0.5) Pass
What I didn’t realize at the time was that the idle stability control valve was connected to the hoses but the multi-pin was off. I replaced the cat this week and reconnected the ISCV. After that it was idling rock steady and driving really well. However, my emissions now are:
Fast idle test
CO = 0.6 Fail
HC = 109 Pass
Lambda = 1.028 (Pass
Natural idle test
CO = 03.62 Fail
To sum up, the lambda levels are now within tolerance but the CO level is worse, and much worse at idle.
The MoT tester said he’d usually suspect the lambda but the lambda was now within spec. After that he’d suspect the cat but that’s brand new. The question is where to go next.
There are no other symptoms of a problem, it’s running and idling fine. It is getting up to temperature properly and the cooling fan is cutting in as you would expect.
Any thoughts or suggestions?
Fast idle test
Natural idle test
Fast idle test
CO = 0.6 Fail
HC = 109 Pass
Natural idle test
CO = 03.62 Fail
