Ryannn
Oct 23, 2013 21:49:33 GMT
Thought I'd try my luck with a modern here... as some old mondeo knowledge probably won't go amiss!
Need some help with my 2002 V6 X-Type.
Runs fine normally and doesn't usually have a problem. Came out to start it today and it's doing nothing. All the dash lights come on as normal but it wont turn over and the starter doesn't make any noise. I tried to bump start it by towing it down the road but again, nothing happened.
Does anyone have any ideas of common faults? It feels like an immobiliser problem to me but I havn't done anything different to it!
Thanks, Ryan
Oct 24, 2013 10:02:06 GMT
Hi mate. Think there's a fuse sumewhere for the starter circuit. Also use a booster just to rule out a bad battery - on a low battery the starter wont even engage the solenoid.
ClassicResto.co.uk - Restoration and maintenance of classic cars - Wolverhampton.
2002 Mercedes E320CDI Estate 1998 Mercedes C240 Sport 1995 Mercedes SL500 1993 Mercedes 500 SEL 1993 Mercedes 500SL - Sold October 2022 1989 Mercedes 300 CE 1985 Mercedes 500 SEC 1985 Porsche 911 Carrera - Sold March 2022 1983 Porshe 944 1978 BMW 1602 1973 Mercedes 350SL
Oct 24, 2013 14:56:20 GMT
Yeah check the starter fuse
Ryannn
Oct 24, 2013 16:48:53 GMT
Will do, thanks guys.
So far I've tried jumping it and bumping it... going to leave the battery off now and check the fuses aswell...
Jag won't turn over...ChasR
@chasr
Club Retro Rides Member 170
Oct 25, 2013 11:08:19 GMT
Has the car had a clutch change etc. recently? I would check the starter motor connections and see whether there is voltage present at the solenoid and main terminals .
Ryannn
Oct 25, 2013 15:51:28 GMT
Right... update... Issue time
There's no fuses blown and I've had the battery off for an hour but that hasn't fixed it either.
AA have been out twice, there's no power to the injector pump or the starter but when you run a live to the starter it turns over but won't fire.
Potentially going to have to find a Jag specialist :/
Oct 25, 2013 17:04:54 GMT
Sounds more like an immobiliser thing to me, might be worth investigating?
I've got Rovers.
Sounds more like an immobiliser thing to me, might be worth investigating? Does your key fob have a battery? If so, change it and try again. Sounds like immobiliser isn't switching.
Life without spanners is no life!
Rover 414 SLI
Ryannn
Sounds more like an immobiliser thing to me, might be worth investigating? Does your key fob have a battery? If so, change it and try again. Sounds like immobiliser isn't switching. It's something to try, not the first thing I thought of because it still locks and unlocks from the key... :/
Ryannn
Oct 26, 2013 10:51:03 GMT
No change with a battery swap... Got an auto electrician coming on Monday.
Onne
Oct 29, 2013 14:32:01 GMT
Is it an Auto? If so might it be worth looking into whether the P-N switch is stopping it from starting? As my Benz will only start in P or N
The immobilizer is nothing to do with the remote system. The transponder chip in the key is separate to the remote system and are programmed separately. Take the key to a locksmiths and see if they can read the chip. If they cant then the chip is knackered. If they can then it could be the chip still or the receiver ring on the ignition or an ecu fault.
sweaty palms slip off joystick
