Onne
Oct 29, 2013 21:01:56 GMT
Went to open the bonnet tonight. Only one click. Drivers side latch won't undo.
Any ideas how to get the bonnet open that doesn't involve copious amounts of violence on my freshly resprayed bonnet?
It's a 1990 Merc 300SE W126
Any ideas greatly appreciated!
Oct 29, 2013 21:32:37 GMT
You'll have to try get at it from underneath or did you try closing down the side that's opening and getting a friend to lean on the side that's not opening whilst you pull the release at the same time
Onne
Oct 29, 2013 21:39:03 GMT
Hi John,
Yes tried that. Going to put her over a pit to have a look. Used to feel two bits of resistance, drivers side unlatching first, then the passenger side.
Being a big bonnet there is a bit of flex in it too.
And really don't want to mess up fresh paint!
Oct 29, 2013 21:41:26 GMT
You should be able to access it then,was the bonnet off,maybe it's just slightly out of line
Onne
Oct 29, 2013 21:48:35 GMT
Apparently not. But the lights were out/loose, which is just about where the cable is.
Hope it's an easy fix tomorrow!
Oct 30, 2013 12:13:36 GMT
Two catches? I do love these over-engineered Benzes.
Onne
Oct 30, 2013 13:12:22 GMT
Yes, one either side of the grille, above the headlight. It does have 4 foot of bonnet to warrant it!
Oct 30, 2013 15:14:20 GMT
Should be able to get to the cable with long nose pliers and pull it through the grille if its snapped ,sacrifice the grille to save the bonnet may be an option but those grilles are better built than most cars lol
Onne
Oct 30, 2013 15:31:37 GMT
Fingers crossed my arms will be long enough to reach it from the back... It feels as if the cable has come out rather than snapped. But I may be completely wrong of course
Onne
All sorted now, managed to get to it from underneath, the cable had popped out.
