Nov 12, 2013 15:22:33 GMT
Last Edit: Nov 12, 2013 16:03:07 GMT by claymore
Nov 12, 2013 18:42:41 GMT
Sorry dude, you're 3 short
Last Edit: Nov 12, 2013 18:43:00 GMT by docjock
Nov 12, 2013 18:49:30 GMT
That hurts my brain
adam73bgt
Club RR Member Number: 58
Multiple turbosadam73bgt
@adam73bgt
Club Retro Rides Member 58
Nov 12, 2013 19:05:41 GMT
I had a bit of a think about whether this would be doable while sat in a lecture last year at uni, I'm glad someone has actually gone out and done it Would lag be almost totally eliminated in addition to it looking cool as hell?
The problem is that a single exhaust pulse every now and then doesn't spool a turbo very well. That 8 turbo V8 was done because they could for a show car and it reportedly didn't work well at all.
But would 5 small turbos designed for something like a 1ltr diesel work?
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Multiple turbosToolsnTrack
@overdrive
Club Retro Rides Member 134
But would 5 small turbos designed for something like a 1ltr diesel work? Its still affected by pulsing. Despite the size of the turbo, if you have only one cylinder feeding it your are missing 3 other cycles which is in effect "dead time", as they are feeding the other turbos. As such, this basically causes the turbo to briefly spool 25% time, then have to wait 75% for the next push in a 4 cylinder application. It would be even worse in a 5 pot (20/80) (Before flames, that was a massive oversimplification, but presented for understanding... )
RobinJI
At least one issue you'll have is the increased skin-friction drag on the air-flow into/out of the turbo's due to the extra surface area of having 4 small pipes instead of 1 large one. I'd imagine the same sort of idea could cause a lot of issues, 4 small turbines are bound to weigh more than 1 turbine capable of flowing 4 times the volume, but they're only being driven by 1/4 of the energy, and so on. It's a cool idea, and doing it because you can is a fair reason, but I wouldn't expect better results than a normal single turbo set-up.
I'd love to be proven wrong though, it does look cool!
Good points, I might just stick to another compound charged setup like the front engine then.
What about adding 5 superchargers too?
Would a setup like the own developments one not work? Surely that spools all 4 turbos all the time?
ToolsnTrack
Homebrew Raconteur
@overdrive
What about adding 5 superchargers too? Couldn't resist...
