LowStandards
After seeing the Commer thread the other day i'm thinking of some new rims for my camper. Thing is there 5" pcd with a 3" centre. What, if anything shares this so I can have a trawl on ebay! Oh, and in case anyone cares, I fitted a new diff to her this weekend, so I can now travel above 40 without getting a headache from all the whining!
5" PCD is easy enough, but the 3" centre bore will be more tricky.
Check out the following... Rover P5, P6, SD1, Austin Westminster, Woleseley 6/110, BMC Landcrab, Austin 3 litre, Leyland Sherpa, LDV 200, Cadillacs (most RWD), Buicks (larger RWD), Oldsmobile (full size), Lincoln (full size Continental, Town Car), Chevy Impala (not all years though!), Jeep Grand Cherokee.
Commer Wheelsarthurbrown
@GUEST
Commer rollin' on Jensen Interceptor rims anyone? SHIZZ!
I knew I'd forget one...
LowStandards
Can the 3inch centre be cut on a lathe or summat without ruining the integrity of the wheels?
@GUEST
I do not know the answer to that. You'd be taking off half an inch of 'meat' at most. How would you test it's strength? Ultrasound or something?
There'd be no need for shiny wheels if it was lowered a bit and you fitted skirts all round ;D
Ether
Where is this Commer appreciation thread? How did I miss it?!?
