andyborris
Nov 26, 2013 17:47:17 GMT
Corsa B with a 1.4 Ecotec engine.
Won't start, but it's got a good spark and petrol is flowing from the injection pump.
Any ideas? Could it be the crank sensor? Or does the ECU need a signal from the crank before sparking and pumping fuel, which would mean the crank sensor is fine (see above!)
Any other ideas? Or should I just weigh it in?
Nov 26, 2013 19:21:30 GMT
Is the pump running while cranking? If so it suggests that ECU does know the engine is turning. Are the injectors clicking/plugs getting wet?
Good luck!
Nick
PS Plan B, weigh in but keep the electric column gubbins.....
Last Edit: Nov 26, 2013 19:22:23 GMT by vitesseefi
andyborris
Nov 26, 2013 19:47:16 GMT
Plan B sounds better all the time, but it's got a pump type steering!
Bloody car, can't even have the decency to be worth something as scrap!
I've pulled the feed pipe to the injection and petrol is flowing, it's got one of those injector systems that like a carb.
bortaf
Nov 27, 2013 10:49:39 GMT
Ah !! single point injection that'll probably be the problem they use a large enough injector to keep up with demand at full throttle but that makes idle and part throttle hard to control, the injector usually dumps to much fuel in and even dribbles constantly in some cases, check the TPS ok as that can cause a perminatly open injector ?
R.I.P photobucket
andyborris
Nov 30, 2013 16:46:32 GMT
Well, got it started.
Poured some neat fuel down the single point injection thing and it fired and run.
Tried unplugging the TPS, likewise the Idle valve was unplugged and neither made any difference to the engines running!
Ordered these 2 bits, £15 so I'll take a gamble.
2 hours later, thought I'd just see if it would re-start, it did and went straight to max revs!
F**king heap of s**t! Never owned a Vauxhall that's been any good!
Onwards and upwards (possibly!)
rodney
Nov 30, 2013 22:28:49 GMT
sounds like the single point , common problems , I had the same with a micra but it was just running like a sloppy turd,.
andyborris
Dec 13, 2013 21:31:49 GMT
New TPS and idle valve fitted, seemed OK for a day or 2.
But now cutting out again as the car slows to a stop and this morning it started, went 20 yards, stalled and wouldn't re-start.
Any thing else, before I give up and ring the scrap-man?
Thanks
Rob
Dec 26, 2013 12:02:54 GMT
change the dizzy mate, theres a hall sensor that dies slowly in it.
andyborris
Dec 26, 2013 12:06:14 GMT
Thanks for the bump, but too late, now scrapped!
No point in trying to MOT a car that may not make it back from the MOT station!
Last Edit: Dec 26, 2013 12:07:51 GMT by andyborris
bortaf
Dec 26, 2013 13:45:37 GMT
change the dizzy mate, theres a hall sensor that dies slowly in it. crank sensor and coil pack on the ecotec aint it ?
R.I.P photobucket
mat91
Scraping is the only way to fix vauxhalls, I can not understand how they are still in business there cars are useless
The stupid is everywhere
