For sale is the space heater that has been much enjoyed at Area 52 for the past few years. The only downside of having it at the unit is that the ceiling height combined with about 4,000sq feet means we're basically using it to heat a massive (drafty and uninsulated) void above our heads unless stood directly in the line of fire.
This will be absolutely perfect for most large workshops, but ideally with a ceiling height less than 20' and/or less than a few thousand square feet.
It looks scruffy, but it works brilliantly and we've used it to burn diesel, red diesel, kerosene and even central heating oil. You can cook toast on it, melt things with it or maybe even warm up your workshop with it?
£60 collected from Bristol (cup of tea and tour of Area 52 provided)
I'll have to try and find the video I took at the same time of it working to show it starting up etc...
[edit] Found it! [/edit]
