Due to needing the wall space for something else, the Area 52 retractable air hose reel is up for sale.
This is the 15m heavy duty one from Machine Mart which retails at £95.98 (Details here)
It's in perfect working order, the mechanism, latch and recoil all work spot on. This comes with the wall mounting bracket and the 'tail'/whip to run to your compressor, but the main hose itself has been removed because it was so old and perished that it was actually leaking from most of its length. You can see this clearly in the above photos. A brand new 15m rubber air hose is only £15 from Machine Mart and fitting is simply a case of doing up one connector. For the extra £15, I am happy to buy and fit a new 15m hose. The rest of the reel is in stunning condition and an ideal way of supplying air to a garage or workshop.
For only £60 you have basically a perfect working air reel with a brand new hose (or £45 if you want to fit your own hose?).
Collection from Area 52 in Bristol with tea provided.
