Dec 16, 2013 23:02:55 GMT
What's the name of the bit of a compressor that the couplings for the airlines are bolted to? The regulator knob and pressure gauges are also attached to it.
Reason for the question; I've snapped a coupling off and need a new one.
Jaguar S-Type 3.0 SE
93fxdl
Enter your message here...
Dec 16, 2013 23:56:46 GMT
If its the bit the airline plugs into, its a quick release connector, trouble being, there are several different types, common ones being PCL. the type most garages seem to and UNI ( afaik ) often used in workshops and the style most cheap compressors and tools come with. Probably best to stick up a pic of broken part to help identity it. Ttfn Glenn
Sounds like the manifold. Pics would help.
If its the bit the airline plugs into, its a quick release connector, trouble being, there are several different types, common ones being PCL. the type most garages seem to and UNI ( afaik ) often used in workshops and the style most cheap compressors and tools come with. Probably best to stick up a pic of broken part to help identity it. Ttfn Glenn Confusing description by me, it's the bit the quick release couplings actually bolt to. Manifold sounds promising.
Dec 17, 2013 10:34:04 GMT
Air regulator/trap possibly
93fxdl
Dec 17, 2013 10:59:28 GMT
Most fittings are 1/4 bsp, a trip to a plumbers merchant should be able to help if you take the broken bit along to show them, might not have identical but should be able to mix and match. If the broken part screws directly into tank it may be 1/2 bsp. When you are there pick up a roll of ptfe tape for sealing the joints. Ttfn Glenn
Jan 12, 2014 15:54:23 GMT
It's taken a while to get around to it but this is the part in question. The casting is about as brittle as a jacob's cream cracker. The part that screws into the tank snapped off when I tried to undo it. The compressor is a Wolf and I'm struggling to find any contacts for them.
93fxdl
Jan 12, 2014 16:55:45 GMT
pork
Jan 12, 2014 21:51:13 GMT
Www.air-technique.co.ukMy company, click on site and follow eBay link to eBay shop for every fitting you can think off
`state
Yorkshire and The Humber
Jan 12, 2014 22:02:52 GMT
Do we get an RR discount Mr Pork?
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
Jan 12, 2014 22:53:00 GMT
It's taken a while to get around to it but this is the part in question. What do i win?
Jan 13, 2014 20:48:16 GMT
It's taken a while to get around to it but this is the part in question. What do i win? A broken compressor manifold.
pork
Jan 13, 2014 20:49:31 GMT
Do we get an RR discount Mr Pork? I'm sure I can sort something out
Jan 13, 2014 20:58:58 GMT
pork
Jan 13, 2014 22:09:32 GMT
I can supply a mini regulator c/w gauge, I've got a selection of T's and reducers to fit, give us the size off where original manifold screwed into compressor and how many outlets you want and il see what I can do pages.ebay.com/link/?nav=item.view&id=170692076817&globalID=EBAY-GB........but the cheap eBay thing you've found is cheaper, but will break again lol
Jan 14, 2014 12:13:56 GMT
I'm slightly torn because it was only a cheap compressor in the first place but let's see. I only need a single outlet. The fitting on the tank is 1/2" BSP, the fitting for the pressure switch assy is 1/4" BSP.
grumpy
Jan 15, 2014 11:05:20 GMT
It's taken a while to get around to it but this is the part in question. The casting is about as brittle as a jacob's cream cracker. The part that screws into the tank snapped off when I tried to undo it. The compressor is a Wolf and I'm struggling to find any contacts for them. I think thats made from lots of melted down mini screwdriver and spanner sets from christmas crackers .
