Jun 14, 2014 22:52:14 GMT
The Monza is finally back at my workshop and is pretty much back in one piece, Just a few little bits and pieces to put back on and then chuck a bucket of water over it and take it for a MOT jobs today. - finished putting the interior in - refit front wings - refit bumpers - fit headlights grill etc - refit body mouldings ( I didn't even break any of the clips ) - fit the new wheels minus the spacers anyway enough waffle, it's picture time.
Jun 14, 2014 23:07:06 GMT
Yeah still working on that bit!
Jun 18, 2014 18:06:57 GMT
The Monza is now finished, for now!! MOT tomorrow, Fingers crossed that it will sail through. Only one way to find out!!
Last Edit: Jul 8, 2014 20:43:35 GMT by Vintage75
Jun 18, 2014 18:23:50 GMT
After driving it around the farm today the suspension has now settled and is a little bit lower than in the picture, but I think a drop of around 50mm will happen as funds allow.
bstardchild
Club RR Member Number: 71
1982 Opel Monza 3.0 'S' bstardchild
@bstardchild
Club Retro Rides Member 71
Jun 18, 2014 20:16:33 GMT
After driving it around the farm today the suspension has now settled and is a little bit lower than in the picture, but I think a drop of around 50mm will happen as funds allow. Don't drop it lower than the tops of the tyre to level with the lowest point of the arches, design of the rear suspension means it adversely affects the handling.
Jun 19, 2014 17:13:48 GMT
As I hoped it passed!!!! But it did get one advisory, slight play in NS front wheel bearing, When I got back to my workshop I checked it and found no play that I could detect. I know I'm not a MOT tester but it seems fine to me,time will tell. I do need to bleed the brakes again as they feel a bit spongie but work ok.
It's finally finished, The brake master cylinder has been changed, The wheel bearing has been tightened (rookie mistake, I checked the wrong side). And I've been doing a couple of subtle mods to give the old girl a slightly different look, I took the Monza out yesterday to put a few miles on just to check everything was OK and I'm glad to report no problems!! At this time! So next stop will be Billing Aquadrome for a weekend of beer and BBQs. Maybe see some of you there, Ps any guises as to what I've done,
Last Edit: Jul 7, 2014 18:03:29 GMT by Vintage75
have you smoked behind the headlight reflectors ?
have you smoked behind the headlight reflectors ? Good spot! That's 1 of 2
Last Edit: Jul 7, 2014 18:04:52 GMT by Vintage75
have you smoked behind the headlight reflectors ? Good spot! That's 1 of 2 That's amazing, how did you get an ashtray in there! Indicators also look darker, not so orange beacon colour.
Last Edit: Jul 7, 2014 19:46:20 GMT by hotfuzz
Well done Phil, yeh the indicator lenses have been tinted, I got a mate to mix up some tinted lacquer and spray them, we had 2 goes at this as the first time they looked great off the car but when I put them on they were too dark and looked totally wrong, but I think we nailed it second time round, enough tint to soften the original in your face amber but with out being blacked out. it's subtle enough that it's not in your face but gives the car a little extra something and freshens things up a bit. I luv it, it's now more my kind of style, now just got to save up and get myself a lowering stick!!
Last Edit: Jul 7, 2014 21:04:10 GMT by Vintage75
That's amazing, how did you get an ashtray in there! As for the ashtray, yeah it's not what you can call easy or a practical place to keep them!
Jan 21, 2015 12:48:48 GMT
Old V's new
Last Edit: Jan 21, 2015 16:41:39 GMT by Vintage75
VIP
Jan 21, 2015 13:08:57 GMT
Ace, look forward to seeing them fitted.
Where did you get them?
Jan 21, 2015 14:15:37 GMT
Thanks, I got them from a chap I know, they came off of his Monza when he lowered his even further! they're Mantzel springs, I have to say they go in a lot easier than the original ones, didn't even need the spring compressors
Last Edit: Jan 21, 2015 17:48:48 GMT by Vintage75
Jan 21, 2015 15:46:58 GMT
Almost there! Got the rear end done today, now to sort the front! Maybe a bit lower than I wanted but hay it's all good
Last Edit: Jan 21, 2015 17:46:09 GMT by Vintage75
bstardchild
@bstardchild
Jan 21, 2015 18:41:15 GMT
It is just a smidge lower than you really want for rear geometry to cope Put Carlton/Senator spring seat pads in there - on the trailing arms - that would probably give you about 5-8 mm which would be bob on Great find on the springs - they look well made and correct wire diameter
bstardchild
@bstardchild
Jan 21, 2015 18:42:31 GMT
Front resolution is easy - choppy choppy - 1 full coil if they are OE springs
Ray Singh
More German exotica in my garage now
Jan 21, 2015 18:53:54 GMT
Looking good!
