So I now am the owner of a domino pimlico mini kit car.
It's a 1966 988cc donor
Was built in 1987 and the current spec is;
998cc bored to 1014cc
Flat topped pistons
12g295 head
Rim flow valves
Fast road cam
Solid rockers
Duplex timing chain
Lightened flywheel
It has a piper x magnum 2780r cam
Vs4 valve springs
Cooper s valve retainers
Gas flowed head
32mm inlet
27mm exhaust
Had a 60 thou skim
And has a 10.26.1 compression ratio
And a AIF6 44 carb with bdl needle and red spring
its is also 542kg kerb weight which is 100kg lighter than a mini.
picked up today here are some pics.
good news the engine block is red
engine bay
side view
front
Flat topped pistons
12g295 head
Rim flow valves
Fast road cam
Solid rockers
Duplex timing chain
Lightened flywheel
Vs4 valve springs
Gas flowed head
32mm inlet
27mm exhaust
Had a 60 thou skim
engine bay
side view
front
