Carter
May 28, 2015 20:51:03 GMT
Oooooh - looking very nice and coming together hopefully in time for the weekend So close...! We got the gearbox and props in this morning, then started on fitting the engine... By the time we knocked off, we were pretty much all in, last job of the day was fitting the recored radiator. I've reshuffled work so I can get back on it tomorrow and finish, double check everything and get some fluids into it. Hope to have it running by lunchtime, and then triple check and set the Weber up.
'77 Chevy G20
conair
May 29, 2015 10:19:38 GMT
Looking Ace fella, do really love this truck.
Carter
May 30, 2015 18:47:37 GMT
Looking Ace fella, do really love this truck. Cheers man! Mutual car love! Coming to Retro Kings at Snetterton?
'77 Chevy G20
May 30, 2015 18:54:53 GMT
Nice buddy !
Well impressed.
Carter
May 30, 2015 19:38:16 GMT
Nice buddy ! Well impressed. Cheers Rian! I should be down your way in a few weeks, will be in the daily as I've got to drop the girlfriend and her daughter at Gatwick. I'll let you nearer the time and see if it's cool to visit yeah?
'77 Chevy G20
Carter
May 30, 2015 19:55:02 GMT
Yesterday we got the truck running, timing sorted, carb adjusted, CO2 test etc, and a test drive... Sorted! Huge thanks to DLF for the engine rebuild and hand-holding! They are stars, a super talented and really sound crew, check them out... Dlfclassiccars.com www.facebook.com/pages/DLF-Classic-Cars/212561501675This was done in between some rolling road sessions. The morning was booked by the guys from Stromberg carbs, testing set-ups on a Model T rod with a corvette engine... The afternoon was booked by a race team with a turbo drag bike, this thing was recording 430bhp with room for more. I didn't get any photos unfortunately, had a brief peek, but the thing sounded insane. So, drove the truck home this morning, it was beautiful. It's also a test of patience now, as I have to run it in and can't go over 3000rpm Retro Kings at Snetterton tomorrow
'77 Chevy G20
May 30, 2015 21:21:12 GMT
Nice buddy ! Well impressed. Cheers Rian! I should be down your way in a few weeks, will be in the daily as I've got to drop the girlfriend and her daughter at Gatwick. I'll let you nearer the time and see if it's cool to visit yeah? Sounds good mate Just check where I am.
Carter
500 miles into running in, all good, and it pulls like a train. Finally scored a genuine Suichuuka shift knob too, been after a 'flower' one for ages. The original jdm ones are now getting very rare, even in Japan, I'm told.
'77 Chevy G20
Looking Good fella !!
Carter
Jun 30, 2015 22:38:25 GMT
I've had some timing chain rattle develop on idle, at first I thought it may be the tensioner- put in a new one on the rebuild but maybe a bad part. On some internet digging it turns out all L series engines will get slack in the timing chain if the head or block has been skimmed, and the easiest way to fix this is to install shims under the cam towers. By wondrous Japanese design, the cam towers share the same bolt pattern and shape across the L range, and fortunately a Nissan/Datsun Z specialist in Essex had a set on the shelf. They were in my hand the next morning. Installed them today Rockers removed, Cam out, taking huge care that the timing chain didn't come off etc Shim installed, one at a time Totally sorted the problem. Running super sweet!
'77 Chevy G20
Carter
Jun 30, 2015 22:50:25 GMT
To celebrate, and considering I've all but run in the engine, we put the truck on the DLF Classic Cars rolling road. Just a run to see how it is, will do a proper session and set up in another couple of hundred miles. And behold the awesome power! Very happy, it should be a little higher next time too
'77 Chevy G20
Jun 30, 2015 23:19:11 GMT
Those shims are a master stroke! Though wouldn't they cause valves to not open quite as far (by however thick they are), not that it matters too much if it works =)
v8ian
Cam should open the valves the same amount, the shim size will be compensated by adjusting the valve/cam clearances
Carter
Cam should open the valves the same amount, the shim size will be compensated by adjusting the valve/cam clearances Yeah, this ^^ Works beautifully, and truck goes like a scolded cat. I hopefully have some new KYB performance shocks for the front turning up today.
'77 Chevy G20
Torque curve looks lovely too, I bet we could get an M45 on there easily enough
Carter
Torque curve looks lovely too, I bet we could get an M45 on there easily enough Lolz er... that won't be happening Dom No more plans engine-wise for now. Other stuff to think about!
'77 Chevy G20
tom83
Beaut.
Carter
Cheers Tom! Out with the old front shocks, more resistance on a bicycle pump... In with the new, less bouncing on the bumpstops! KYB Performance Shocks will do for now... Need to have another play with the torsion bar height now I have suspension again.
'77 Chevy G20
