Feb 11, 2014 20:39:13 GMT
I would like to remove the Clifford alarm on the Audi cabby i have just bought as it is driving me mad.
I have started to to trace a lot of the wires back is it just a case removing all the wires or is thier a quick fix of finding the break in the loom that prevents it being started when the alarm is engaged and joining them together?
Steve
Ginetta G15 BMW K1100 conversion Sold Mk1 Mx5 on ITB'S Sold TVR Chimaera 400 supercharged MR2 Red Roadster 2ZZ Bee*R 324 Skyline 95 Cherokee Jeep
Id start with trying to find a wiring diagram or installation manual for the alarm from there and working backwards.
Double post, sorry
Last Edit: Feb 12, 2014 2:12:48 GMT by metroman
Club RR Member Number: 160
Removing AlarmRich
@foxmcintyre
Club Retro Rides Member 160
Trace wires back and join any that the alarm interrupts. Not that hard to do, just time consuming.
Feb 12, 2014 11:08:01 GMT
As said trace it all back and redo it all , unfortunately Clifford alarms are cat 1 usually so it means there will be at least 2 immobilised circuits , usually fuel pump and also spark , these will be done by cutting the live wire on each circuit and feeding them through two Clifford wires (this bypasses the circuit through the Clifford ). You need to resplice the original wire in your loom together
Make sure you solder all the joints and don't scotch blok them ,
