ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Basically, whats the best stuff to let glass run smoother on rubber? My MX5's window gets stiff on the last inch of travel before closing. I'm guessing the rubbers within the guide are drying out, but is there an old wives trick for something i can lubricate it with that will let it move better, but not end up with greasy streaks all over the glass every time?
What works for you guys?
Club RR Member Number: 160
Cheat for lubricating window runners?Rich
@foxmcintyre
Club Retro Rides Member 160
Better to check the cables or quadrants are not running dry before salthering the runners in cack that will forever end up on the glass. Take the panel off and check/lube the working parts of the lift mech first. 9/10 at work when I'm asked to 'lube the window guides, it's sticky' it's actually cables beginning to rust and needing lubrication.
Spray mr sheen on the rubbers and clean the window with it.if it doesn't work it's the runners
steveg
I have used silicone brake fluid in the past after someone suggested it to me. A quick squirt of normal silicone spray will help but it doesn't last so long.
ToolsnTrack
Homebrew Raconteur
Thanks for the tips guys. I'll have a look at the runners first then, as I'll be doing the door speakers shortly.
Cheers!
bortaf
Feb 20, 2014 11:47:16 GMT
Clean the runners as best you can then silicone polish the hell out of em, them i use chain wax all in the mechanism, seems to last well and not wear off ?
R.I.P photobucket
taurus
Feb 20, 2014 12:53:33 GMT
I use silicon lubricant spray on them.
Feb 20, 2014 14:04:18 GMT
rodney
Feb 20, 2014 15:22:11 GMT
baby powder in the rubbers , no greasy dramas,.
Feb 20, 2014 22:07:21 GMT
Graphite? (a pencil).
I've had the same a few times, I thought it was down to worn mountings, warping the whole mechanism.
Feb 21, 2014 14:39:37 GMT
Use a flat blade screw driver to get all the grime and moss out and stretch the channel open slightly them a small amount of Vaseline worked into the channel using a cotton bud that way you don't get any on the glass.
